2010 Liberty won't start. Electricly dead - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KK Liberty Forum > 2010 Liberty won't start. Electricly dead
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 07-29-2014, 07:10 AM   #1
seniorrip
2010 Liberty won't start. I Turned the key and everything turned off. It was as if there was no power at all. I popped the hood and heard a clicking from the start run solenoid in the fuse box. I swapped it out and still nothing. I jumped it and everything turned back on but still no crank. I get one click but no starter cranking.
seniorrip is offline   Reply With Quote Quick reply to this message
Unread 07-29-2014, 07:35 AM   #2
hvteng
Hi, have you checked your battery?
hvteng is offline   Reply With Quote Quick reply to this message
Unread 07-29-2014, 07:49 AM   #3
seniorrip
I checked the connection and jumped it just in case. I had already driven it a half hour already this morning and just turned it off for 5 min when this problem happened.
Unread 07-29-2014, 08:04 AM   #4
RENE65
2008 KK Liberty
Still sounds like a dead battery , check the battery voltage when you try to crank before swaping everything. Always check the basics before getting into it deeper.
RENE65 is offline   Reply With Quote Quick reply to this message
Unread 07-29-2014, 08:57 AM   #5
seniorrip
It doesn't crank at all but I'll try replacing the battery.. Thanks guys
