2010 Liberty transmission cooler. - JeepForum.com
post #1 of 8 Old 11-23-2010, 02:21 PM Thread Starter
Krieg
Hello, I'm a Jeep newbie so obviously new to the forum. Just bought a 2010 Liberty Sport and added an aftermarket trailer hitch receiver. It looks like my Liberty already came with a transmission cooler based on an under vehicle check and verification on MOPAR's parts website.
Is this standard on the 2010's? Is there anything else I need to add to bring the Liberty up to the 5000 Lb. rating?
Much thanks in advance for any help.
Krieg is offline
post #2 of 8 Old 11-23-2010, 02:30 PM
tjkj2002
2002 KJ Liberty
Your Liberty has a stand alone trans cooler,not a good setup for towing.For towing you want to have a in-radiator trans cooler then route the trans fluid to a AUX stand alone cooler then back to the trans,the best setup.Reason being the in-radiator cooler helps warm up the trans fluid so the trans operates correctly faster,also controls temp spikes in the fluid much better then just a stand alone cooler,then the AUX stand alone cooler drops the fluid temps down some then back to the trans to start the process all over.
'04-'11 Liberty's all use the same trans cooler setup and it is a common problem for the trans temp light to turn on when pushed hard,even with HD cooling,seen it all the time wheeling here in Colorado.You never hear about or see the trans temp light come on in '02-'03 Liberty's with just the in-radiator trans cooler(45RFE trans only),with or without HD cooling in the same conditions.
tjkj2002 is offline
post #3 of 8 Old 11-23-2010, 02:34 PM Thread Starter
Krieg
Thank tjkj, does Mopar offer the set-up you describe? Are there any other upgrades (aside from tranny cooling)? Thanks for the fast response!
Krieg is offline
post #4 of 8 Old 12-06-2010, 04:56 PM
SuperRliBerty
2008 KK Liberty
This radiator has a transmission cooler. Essentially the transmission fluid is circulated in the radiator and is "cooled" by the coolant
2008 Sport Liberty
Cold air intake*Trush (magnaflow) turbo muffler* Hypertech power program*
Hood Prop mod. Battery Quick Release mod.
Resonator removed (sounds like a V8 on start up)
SuperRliBerty is offline
post #5 of 8 Old 07-21-2017, 10:04 AM
Happycow
I have a 2010 Jeep liberty I have to replace the transmission cooler Is it ok to use a after market tranmisson cooler and bypass the air condenser is Cheeper to replace it that way
Happycow is offline
post #6 of 8 Old 07-21-2017, 10:28 AM
Happycow
10 jeep liberty my transmission cooler needs to be replaced can I use an aftermarket transmission cooler to replace it The run through the air conditioner condenser this one won't it will is be separate
Happycow is offline
post #7 of 8 Old 07-21-2017, 10:29 AM
Happycow
I have a 2010 Jeep liberty my transmission cooler needs to be replaced can I use an aftermarket transmission cooler The old transmission cooler seems to run to the AC condenser but this one will be separate it is it is it OK to use
Happycow is offline
post #8 of 8 Old 08-10-2017, 03:54 PM
Steve40th
Did they change that in 2012? Why would they not integrate a cooler with radiator?
Steve40th is offline
2010 Liberty in the shop... z06boy KK Liberty Forum 5 11-04-2010 09:35 PM
Little help with 2010 Liberty alex725 KK Liberty Forum 16 11-04-2010 09:31 PM
2010 Jeep Liberty with Sun Slider vs. 2010 4dr. Unlimited ?? britt22 KK Liberty Forum 20 10-08-2010 12:49 PM
Opinions on 2010 Liberty? planetlarson KK Liberty Forum 14 10-07-2010 05:28 PM
2010 Liberty "Renegade" with Transmission Vibration davebwi KK Liberty Forum 4 08-09-2010 11:39 AM
