2010 Liberty Anti-Freeze - JeepForum.com
post #1 of 6 Old 09-22-2013, 12:57 PM Thread Starter
pauld73
2010 KK Liberty
I just checked my coolant level in the overflow container and the level is below MIN with engine off and engine cold. The anti-freeze that's in there is the factory installed pink stuff. I have some Prestone anti-freeze mixed with distilled water so that it's 50% anti-freeze and 50% water. Is there anything special about Liberty anti-freeze or can I mix my Prestone mixture right in with the factory stuff?
Paul
pauld73 is offline
post #2 of 6 Old 09-22-2013, 05:42 PM
tjkj2002
2002 KJ Liberty
DON'T pour that junk in your cooling system.Prestone does not make the correct coolant for your Jeep.
Only use...............
-MOPAR HOAT coolant
-Zerex GO5(gold bottle)
-Ford's Premium Gold coolant
tjkj2002 is offline
post #3 of 6 Old 09-22-2013, 07:37 PM Thread Starter
pauld73
2010 KK Liberty
ok tj thanks. I broke down and read the owners manual and they say only use HOAT cooolant also.
Thanks for your reply
pauld73 is offline
post #4 of 6 Old 09-24-2013, 11:26 PM Thread Starter
pauld73
2010 KK Liberty
I got a bottle of Zerox G05 at NAPA, the last one they had.
pauld73 is offline
post #5 of 6 Old 09-24-2013, 11:32 PM
Poncherello
2010 KK Liberty
Make sure when you look at the coolant I think its hoat, its pink and should have something on it saying its Chrysler certified.
When you get knee-deep in a situation, floor it.
Poncherello is offline
post #6 of 6 Old 09-24-2013, 11:53 PM Thread Starter
pauld73
2010 KK Liberty
Yup the jug says "approved by Chrysler, Ford etc right on it.
Jug Says Zerex G-05. I went to Autozone and they were clueless about HOAT and OAT antifreeze. They pushed Prestone Extended ALL makes ALL models on me and I bought it. When I read the owners manual I took it back and went to NAPA and got Zerex. There is a lot of confusion about the proper anti-freeze to use. My question is How can Prestone claim right on their jug that it works with ALL MAKES and ALL models? I think that if you are flushing the cooling system and starting fresh, you probably can get by with Prestone.....BUT, if you're topping off your Factory anti-freeze, then you better use HOAT or you get all this sludge from the chemical reaction that is created between Prestone and the Factory HOAT stuff.
Paul
pauld73 is offline
