2010 KK Renegade heat/ac problem - JeepForum.com
post #1 of 4 Old 11-17-2012, 12:58 PM Thread Starter
Redredjeep
Blower has only one speed, will not cut off, a/c seems to work,recl. also (lights come on knobs). My system is the auto temp. control, turn that knob
no change, 3rd knob for vent,def.,heat, select...turn knob no change.
My findings point to blower resistor from other forums but can't find any parts for 2010 year mod.
I am trying to avoid the stealership, any ideas?
Redredjeep is offline
post #2 of 4 Old 11-18-2012, 06:47 AM
cke91082
Mine has the same problem. I took mine in though because it was still under warrantee....are you not?
cke91082 is offline
post #3 of 4 Old 11-19-2012, 10:56 AM
lfhoward
2008 KK Liberty
Factorymoparparts.com has the 2010 blower motor resistor for $57. Search the catalog for the 2010 Libby under HVAC / Controls. It should be pretty easy to install yourself. I did this repair on my 2000 XJ back in the day and it's as simple as using a screwdriver and unclipping wiring harnesses. The resistor lives under the dash or behind the glovebox somewhere.
2008 Liberty Sport 4x4 Automatic
lfhoward is offline
post #4 of 4 Old 11-21-2012, 07:51 PM Thread Starter
Redredjeep
Problem fixed!!
Took it to the dealer, (still under warranty) found that it was a defective control unit, it had to be ordered and sent overnight to dealer. Was in & out in under 30 min.
(they replaced the panel w/ the 3 knobs)
1st time for any warranty work on this Jeep, and I didn't buy it from this dealer. No hassle, the way it should be.
