2009 Rear Window Leak - JeepForum.com
post #1 of 47 Old 12-25-2009, 05:24 PM Thread Starter
spolebitski
In addition the the seats squeaking ... I now notice that my rear window leaks. I have noticed that the window has streaks down it but yesterday I really noticed that is was due to water .... ahhhh.
Anyone else have an issue with the rear window leaking?
spolebitski is offline
post #2 of 47 Old 12-25-2009, 05:27 PM Thread Starter
spolebitski
I must note on 12,000 Miles so far going on 11 months of ownership.
post #3 of 47 Old 12-25-2009, 07:18 PM
richd
2008 KK Liberty
The early 08 KK had this problem,and I didnt see any TSB for the 09s for this.I would mention the TSB to your dealer.
Make : JEEPModel : LIBERTYYear : 2008Manufacturer : CHRYSLER GROUP LLC Service Bulletin Number : 2305407Date of Bulletin : DEC 12, 2007NHTSA Item Number : 10023645 Component : STRUCTURE:BODY:HATCHBACK/LIFTGATESummary :
WATER LEAK ON LOAD FLOOR ON RIGHT OR LET SIDE OR BOTH AT THE LIFTGATE HEADER AND/OR THE LUGGAGE RACK CHANNEL SEAM AREA. *NJ
richd is offline
post #4 of 47 Old 01-21-2010, 07:24 PM
daledoe
2009 KK Liberty
I have on 09 Liberty and I believe I am having the same problem. I havent had a chance to fully inspect it but i have noticed streaks of water running down my rear window that the wiper is magically missing so it must be inside.
daledoe is offline
post #5 of 47 Old 01-24-2010, 11:17 AM
fmdualexhaust
Rear window gasket replaced on the wife's '08 about 3 months ago w/25000 on the clock.
Just noticed the "streak" inside my '09 window. Going in for the annual state inspection next week and will point this out to the service mgr.
fmdualexhaust is offline
post #6 of 47 Old 01-26-2010, 08:25 PM Thread Starter
spolebitski
What is the annual state inspection?
post #7 of 47 Old 01-27-2010, 02:07 PM
coder
2010 KK Liberty
I am having the same problem. I plan on taking my 2010 to the dealer and see what they can do. Hopefully they will replace the weather stripping with some sort of newly designed, thicker version.
coder is offline
post #8 of 47 Old 01-27-2010, 04:11 PM
Busch2fan
2008 KK Liberty
The back window leaks a little but isn't a problem. The moon roof leaks a little too when I go thru one of those brushless car washes. Only comes in when the water is spraying directly on the window.
Busch2fan is offline
post #9 of 47 Old 01-30-2010, 01:23 PM
fmdualexhaust
State safety inspection. Tires,brakes,lights, etc.
post #10 of 47 Old 03-11-2010, 02:38 PM
z06boy
z06boy's Avatar
2010 KK Liberty
I have a 2010 with a leaking rear window as well. I took it in and had the seal replaced on the rear window BUT noticed a couple of drops this morning on the cargo cover so I'll be looking into that.
*EDIT* Ok we had some rain here yesterday...last night and again a bit this morning and I checked 3 different times and NO water inside the rear hatch area.
I just had the leak repaired Wednesday so MAYBE those couple of drops that I saw were leftover from the dealership testing the area and not new wetness.
I will report back later if I notice anymore water but it may have been repaired properly.
z06boy is offline
post #11 of 47 Old 03-13-2010, 05:01 AM
kenjeep
2010 KJ Liberty
I had the same problem here on my '09 and '10 Jeep liberty. Tried replacing seal, cleaned the seal. Can't make the leak go away. I ended up putting some lithium grease on the seal, close the window and never open it again. Just ended up only using the tailgate. Anyways, the lift height is way too high to load any grocery bags or small packages.
kenjeep is offline
post #12 of 47 Old 03-13-2010, 05:57 AM
Bayrat
2014 JK Wrangler
I'm not sure how the water is drained from a Liberty sunroof but if it's like most, there is a "pan" around the perimeter that has some sort of drain to carry water away. Check to see the drains are not partially blocked and not eliminating water quickly enough. No sunroof should leak in a car wash.
Bayrat is offline
post #13 of 47 Old 03-14-2010, 06:25 AM
jamski
2015 KL Cherokee
I noticed a few dribbles last night on the inside of my rear window of my '10. We had a lot of rain last night--not hard, but constant. I opened the window and shut it, and the leak seemed to have stopped. Hopefully it was a fluke.
So far, no sunroof leaking.
jamski is offline
post #14 of 47 Old 03-16-2010, 04:29 PM
LILRHODIEJEEP
I Leased a 2010 Liberty, two weeks in the back window leaked. I took it to the dealer. They CLAIMED they replaced the entire back end. The next rain - MORE LEAKS. Dealer took the Jeep again (one week later) and said I was crazy. I just brought the danged thing back again to be fixed. I have owned the Jeep since Jan 28 2010. For whatever reason Metro cannot seem to repair the window leak. RI Lemon Law dictates after 4 attempts Jeep/Chrysler has to replace the vehicle. I am hoping they have to, I will pick another Chrysler product - its apparent Jeep has an inherent defect in the rear window. I really loved Jeeps but now I see (from this forum) there are nothing but hassels owning a Jeep. The funny thing is, the dealer thinks they fooled me, thinks I fell for it when they claimed they replaced the whole back gate. The proof they did not is in the pudding - the window still leaks! WHY BOTHER TO LIE?????? Shaking my head.
LILRHODIEJEEP is offline
post #15 of 47 Old 03-17-2010, 08:44 AM
z06boy
z06boy's Avatar
2010 KK Liberty
As long as my leak is just a few drops here and there...no biggie to me. I won't try to use the Lemon Law to get them to take back the vehicle...not that big of a deal to me. It's supposed to rain Sunday so I'll check to see if the leak has 100% been repaired.
z06boy is offline
2009 jeep liberty - wont start / wont even crank aimetti KK Liberty Forum 38 02-19-2016 09:46 AM
Help: jeep liberty 2009 8" ROOF antenna NEEDED bobbarto KK Liberty Forum 25 09-09-2011 05:52 AM
2009 Jeep Liberty Issues JBWrangler2000 KK Liberty Forum 10 09-29-2010 09:55 AM
Prices Paid for 2009/2010 Liberty Limited britt22 KK Liberty Forum 10 06-14-2010 12:15 PM
Removing Turn Signals? 2009 KK JFD140 KK Liberty Forum 4 12-22-2009 11:51 AM
