2009 Liberty Floor Pan flooded with water - JeepForum.com
post #1 of 3 Old 04-05-2011, 12:16 AM Thread Starter
rdp8
I have a 09 Liberty after warranty expired I started to notice the drivers side floor pan totally flooded. I`ve already know that`s water coming from a/c evaporator box. So, anybody know how to repair this problem or if there is any part diagram that helps how to reach the evaporator box and repair this problem?
rdp8 is offline
post #2 of 3 Old 04-05-2011, 07:29 AM
sloan74
Seal on the condenser maybe? See if you can dig up/google a manual perhaps and see if there is an easy way to get to it via diagram.
sloan74 is offline
post #3 of 3 Old 04-05-2011, 02:43 PM
griff02
2008 KK Liberty
don't have any idea if this is related, but my passenger side was flooding with water every time it would rain. It was coming from a hole in the body behind the kick panel, draining down from somewhere. It appeared that it was supposed to be filled with foam, but apparently it had an air pocket or channel that did not get sealed. Anyway, I took a can of "great stuff" and sprayed it in the hole until it ran back out, and wa la, it was sealed off with foam. Hasn't leaked since.
Reason I mention this, is because there is an identical hole on the drivers side, but mine was sealed off correctly on that side. But if yours is getting wet without rain, I would say this is not related.
griff02 is offline
