2009 Jeep Liberty heat issues - JeepForum.com
post #1 of 7 Old 12-21-2014, 08:10 PM Thread Starter
2009JeepLiberty
I have a 2009 Jeep liberty Rocky mountain edition. The heater is having issues firstly the heat doesn't work while idling and the drivers side is always colder than the passenger side. I have been troubleshooting this issue for about two months and so far i have noticed the coolant level stays constant, I'm not having overheating the temp gauge remains stable through out my driving and I flushed the heater core. I'm not sure where to turn for advice i have plenty of experience with car maintenance from oil changes to full brake replacements but troubleshooting is not one of my strong points. I don't have engine codes to work with the trouble lights have not been on except one time when i forgot to put my gas cap on.
2009JeepLiberty is offline
post #2 of 7 Old 12-22-2014, 04:43 PM
Jeff88
I have this identical issue in our 2009 Liberty.
Anyone?
Jeff88 is online now
post #3 of 7 Old 12-23-2014, 06:08 PM
griff02
2008 KK Liberty
If its actually a lack of heat I'm not sure, but does it sound like it is blowing strong and you just don't feel the heat coming out at the floor? If so it could be the diverter flap thing. Not sure what it is really called, but it changes the direction of the air, and apparently the existing one is not strong enough. My '08 does it. Seems to continue to mostly blow out the defrost (or just feels like it is blowing with no escape) even though it is set at the floor. Someone had a breakdown of the repair, and it seemed pretty involved. I think its a fairly common problem.
I'm sure someone will post that has a lot more knowledge of it than me, my details of it is pretty vague.
griff02 is offline
post #4 of 7 Old 12-23-2014, 06:12 PM
Jeff88
Mine feels like the air is blowing out where it is supposed to, but its like cooler air when at a stop light. Then it gets progressively warmer when you drive, but never warm enough to consider it to be an adequate heater.
post #5 of 7 Old 12-30-2014, 12:59 PM Thread Starter
2009JeepLiberty
The air is being directed as expected the issue is with the temperature. It is cold at idle and when driving the temp of the heat coming out increases. However the heat is considerably cooler on the drivers side regardless of what setting. When I stop at a light the temp decreases to the approximate outdoor temperature.
Just to be clear i am referring to the temperature of the Heat coming from the vents. The on-board engine temp sensor registers the temp in the center of the gauge consistently.
post #6 of 7 Old 12-30-2014, 01:14 PM
Nyfurri22
heating issue
I'm having the same issue with my 2009 Jeep Liberty. Please let me know what you do to fix. I have already flushed the heater core and changed the coolant.
Nyfurri22 is offline
post #7 of 7 Old 06-10-2015, 10:24 AM
Jeff88
Finally just had a shop flush the system and also flush the heater core independently and I have heat very strong again. Of course it will be 93 degrees here today, so I don't need it, but come winter, I will be able to keep this vehicle as a daily driver now!
I used a good local shop that told me there was a lot of sediment in the core. I don't know how they know that exactly.
