2008 Sport Liberty squeling when turning - JeepForum.com
post #1 of 7 Old 01-15-2010, 10:37 AM Thread Starter
amike_321
I have a 08 Liberty Sport that is squealing when turning out of driveway and parking spots. Any tips or hints on what to check. Just started this since the temps got cooler. I will inspect the belts and power steering pump/pulley/tensioner this afternoon. Just wanted to find out if there is something else to check while Im in there. Thanks.
amike_321 is offline
post #2 of 7 Old 01-15-2010, 10:44 AM
Elt31987
Elt31987's Avatar
2008 KK Liberty
Sounds like a loose belt
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #3 of 7 Old 01-15-2010, 10:48 AM Thread Starter
amike_321
These use a serpentine belt with a tensioner, correct?
post #4 of 7 Old 01-15-2010, 11:19 AM
Elt31987
Elt31987's Avatar
2008 KK Liberty
Yes they do.
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #5 of 7 Old 01-15-2010, 11:20 AM
diggerfreek
2008 KK Liberty
Yes, the KK uses a tensioner, and unless you have a lot of miles on your KK, the tensioner probably isn't bad. Have you checked the level of the fluid yet? Also, be sure to use only ATF+4 if you need to top it off.......
diggerfreek is offline
post #6 of 7 Old 01-15-2010, 11:23 AM Thread Starter
amike_321
It is right at 20K right now. Its my wife's Jeep and she said it was squealing. I change the oil and other maintenance stuff. I usually look around under the hood when I am doing that but didn't see anything out of the ordinary two weeks ago.
The fluid level is first on my list, then checking the tensioner. Thanks for the info.
post #7 of 7 Old 01-19-2010, 06:53 AM Thread Starter
amike_321
Checked it out over the weekend, I could not get the belt to squeal. Fluid level looked fine, tensioner appears okay, belt tight.
I told my wife, "NO more water crossings!"
2008 Liberty Headlight Adjustment sbougon KK Liberty Forum 10 12-03-2013 06:02 PM
snorkel for liberty kk david1980 KK Liberty Forum 6 05-03-2013 08:28 AM
Liberty Gas Mileage jeepkid60 KK Liberty Forum 63 11-29-2010 01:12 PM
15's on an 08 Liberty>?? CoachRamirez KK Liberty Forum 2 02-06-2010 10:28 AM
2008 KK lift? GilNewJeeper KK Liberty Forum 6 01-05-2010 08:19 PM
