2008 Liberty - Preventative maintenance - Page 2 - JeepForum.com
post #16 of 34 Old 03-25-2011, 03:47 PM Thread Starter
SuperRliBerty
2008 KK Liberty
I cleaned the intake throttle body of my jeep last week and I immediately notice a difference in the idling. I must mention, I also replaced the spark plugs and it also contributed to my silky smooth idle.
The valve cover breather hose is plumbed back into the intake tract
Carbon buildup and a oil film residue can cause this:
Date Reported: MAY 01 2009
NHTSA Reference: #10030707
TSB Reference: #SB-18-013-09
Description: JEEP: IN COLD CLIMATES A MIL (check engine light) ILLUMINATION P0123 OR P0222 OR STORED DIAGNOSTIC TROUBLE CODE P0123 OR 00222 AND THE ETC LIGHT ILLUMINATED. THIS INVOLVES REPLACING THE ELECTRONIC THROTTLE BODY AND/OR CLEAN AIR DUCT. FAILING THROTTLE BODY OR EXCESSIVE CARBON BUILDUP*PE
This is a pic of my libby's throttle body after cleaning...
2008 Sport Liberty
Cold air intake*Trush (magnaflow) turbo muffler* Hypertech power program*
Hood Prop mod. Battery Quick Release mod.
Resonator removed (sounds like a V8 on start up)
SuperRliBerty is offline
post #17 of 34 Old 03-25-2011, 04:24 PM
VMF
2008 KK Liberty
looks good, should have made the b4 picture as well
what did you use for cleaning?
toothbrush?
___________________________
2008 KK limited 4x4. Inferno Red
2009 JK Rubicon. Black
2004 UCF31. Black
2001 EM2. Inca pearl
2012 UD Limited. Royal Gray
VMF is offline
post #18 of 34 Old 03-26-2011, 12:12 AM
BloodyShadow23
2008 KK Liberty
So, I tend to find that the Jeeps in my family (my old '98 XJ Cherokee, my mom's '06 WK Grand Cherokee, and my '08 KK Liberty) have a problem with squeaky brakes. Is that just because of the brake dust or something else? Anything I can do to fix that?
2008 Liberty Sport - Chrome Grill, K&N CAI,
BloodyShadow23 is offline
post #19 of 34 Old 03-26-2011, 09:21 AM
VMF
2008 KK Liberty
what brand r u using? r u putting shims on? r u using antisqueack?
2004 UCF31. Black
VMF is offline
post #20 of 34 Old 03-26-2011, 01:59 PM
BloodyShadow23
2008 KK Liberty
I haven't done anything to it yet. I don't want to screw up my brakes and anything else for that matter.
post #21 of 34 Old 03-26-2011, 04:59 PM Thread Starter
SuperRliBerty
2008 KK Liberty
toothbrush?
tooth brush ? ..... Actually, It was quite clean, so I cleaned it with a shop rag. They were No oily residue, just a little amount of carbon buildup (from the EGR).
This is the "recommended way" to clean the throttlle body
This is a TB from a 6yr old toyota
Some have suggested using carb cleaner to remove the oil deposit, But this is safe to use
0904gmhtp_05_z-throttle_body_and_air_intake_cleaner-napa_throttle_body_and_air_intake_cleaner.jpg
2008 Sport Liberty
post #22 of 34 Old 03-26-2011, 05:37 PM Thread Starter
SuperRliBerty
2008 KK Liberty
About six months after I bought my liberty, I install the K&N filter. The valve cover breather hose was not connected back up and it began a "whistle" at idle and became louder as the speed increase.
I installed a "baby" "mini me" filter on the hose.(see pic).
If you installing a CAI system, make sure the breather hose air is connected back into the intake tract.
2008 Sport Liberty
post #23 of 34 Old 03-26-2011, 05:57 PM Thread Starter
SuperRliBerty
2008 KK Liberty
Try this chart it shows what should be lubricated to eliminate squeaks.
2008 Sport Liberty
post #24 of 34 Old 03-31-2011, 02:13 PM
09_Silver
2011 KK Liberty
How many miles did you get out of the plugs you replaced? Were they the originals? How bad did they look?
'11 Liberty Jet Sport - 4x4
09_Silver is offline
post #25 of 34 Old 03-31-2011, 02:30 PM Thread Starter
SuperRliBerty
2008 KK Liberty
I have 72,000 miles on my J-lib. I replaced the factory spark plugs every 30k miles. I was told the Bosch platinum will last 100k miles, so I will change them at that time.
2008 Sport Liberty
post #26 of 34 Old 04-10-2011, 04:36 PM Thread Starter
SuperRliBerty
2008 KK Liberty
There was an oily film on the a/c low pressure line (pic), I immediately thought it was freon leaking, but it was clean and the viscosity was not consistent with freon fluid. A/c runs cool as an eskimo's A hole.
Solved: On my last oil changed, I removed the funnel and some oil dripped on the a/c pressure line.... cleaned it up and ran the a/c. Cools like a bud light.
I have written about this so I am gonna fabricate something to remedy the problem. Every time you use the a/c, condensated water settle on the no. 2 spark plug coil pack. it is soon evaporated but I wish Jeep had routed the hose away from the coil pack.
2008 Sport Liberty
post #27 of 34 Old 04-10-2011, 06:18 PM
tjkj2002
2002 KJ Liberty
Good luck with that.
tjkj2002 is offline
post #28 of 34 Old 04-11-2011, 07:42 AM Thread Starter
SuperRliBerty
2008 KK Liberty
... I am feeling lucky like Clint eastwood, but honestly I will change it long before.
whether it is platinum, titanium or frigging aluminum, NO SPARK PLUG will last 100,000 mile, so bosch, ngk, champion, a/c delco, autolite is blowing hot air
2008 Sport Liberty
post #29 of 34 Old 04-12-2011, 10:12 PM
BloodyShadow23
2008 KK Liberty
Or making hot air. HEY OH!
post #30 of 34 Old 04-25-2011, 06:32 PM Thread Starter
SuperRliBerty
2008 KK Liberty
Well it was 93 degrees today in sfla, and my J-lib stayed cooled and idled perfectly. I am ready for 100+ degree weather
2008 Sport Liberty
2008 Liberty Headlight Adjustment sbougon KK Liberty Forum 10 12-03-2013 06:02 PM
2008 Liberty Skyslider Issues JFK2218 KK Liberty Forum 39 04-05-2012 11:31 AM
which lift for 2008 liberty kk flaglfr KK Liberty Forum 0 02-01-2011 08:53 PM
2008 Liberty mods for 2011 SuperRliBerty KK Liberty Forum 5 12-03-2010 05:35 PM
2008 Liberty mechanical fan noise JWMII KK Liberty Forum 2 11-21-2010 08:09 AM
