2008 Liberty - Preventative maintenance - JeepForum.com
post #1 of 34 Old 02-08-2011, 04:33 PM Thread Starter
SuperRliBerty
2008 KK Liberty
Including all fluids and filter change, several times a year I lube the entire Liberty. I use WD40. It displaces 40% of water, moisture. (hence Water Displacement 40%).
Today I notice, the intake tube was rubbing against the a/c aluminum high pressure line. ( first pic. arrow)
I loosen the clamp at the throttle body and repositioned the intake tube away from the a/c line. they was a black scuff mark on the line, cleaned it and noticed a "gouge" in the same spot.
Check for clearance between the a/c and intake tube.
2008 Sport Liberty
Cold air intake*Trush (magnaflow) turbo muffler* Hypertech power program*
Hood Prop mod. Battery Quick Release mod.
Resonator removed (sounds like a V8 on start up)
SuperRliBerty is offline
post #2 of 34 Old 02-08-2011, 04:42 PM
otlip
thanks for the heads up!
otlip is offline
post #3 of 34 Old 02-09-2011, 04:08 PM Thread Starter
SuperRliBerty
2008 KK Liberty
I grab my bottle of WD40 and begin from bumper to bumper. First, I lube the hood latch....
Then a squirt of WD40 on the hood strut ball joints.
The Hood hinge
Front Sway Bar Bushing
2008 Sport Liberty
post #4 of 34 Old 02-09-2011, 04:15 PM Thread Starter
SuperRliBerty
2008 KK Liberty
Double squirt Any rubber bushings on both front wheels suspensions, including the upper and lower "A" arms..
2008 Sport Liberty
post #5 of 34 Old 02-09-2011, 04:22 PM Thread Starter
SuperRliBerty
2008 KK Liberty
The (engine side) steering U joint
(Under the dash) steering U joint
2008 Sport Liberty
post #6 of 34 Old 02-09-2011, 04:32 PM Thread Starter
SuperRliBerty
2008 KK Liberty
Engine Mount (both sides)
Transmission mounts can be squirted with WD40
2008 Sport Liberty
post #7 of 34 Old 02-09-2011, 04:34 PM Thread Starter
SuperRliBerty
2008 KK Liberty
The "A" arm
2008 Sport Liberty
post #8 of 34 Old 02-09-2011, 04:44 PM Thread Starter
SuperRliBerty
2008 KK Liberty
Front door hinges. If there is any surface rust, spray WD40 and a cloth and wipe it off, then spray some on the hinge
Turn 180 degrees (Back of you) and you will see the rear door hinge exposed. Clean the surface rust and spray. Lube grease can be used on the hinges too.
2008 Sport Liberty
post #9 of 34 Old 02-09-2011, 04:57 PM Thread Starter
SuperRliBerty
2008 KK Liberty
Rear pitman arm bushings
Rear sway bar bushings
sway bar torque link bushing
The spare tire pulley and spring
2008 Sport Liberty
post #10 of 34 Old 02-09-2011, 05:02 PM Thread Starter
SuperRliBerty
2008 KK Liberty
Rear Liftgate hinges
Rear liftgate strut ball joint
2008 Sport Liberty
post #11 of 34 Old 02-12-2011, 11:33 AM
VMF
2008 KK Liberty
im actually gonna go and do most of that to our KK now. thanks for the idea
___________________________
2008 KK limited 4x4. Inferno Red
2009 JK Rubicon. Black
2004 UCF31. Black
2001 EM2. Inca pearl
2012 UD Limited. Royal Gray
VMF is offline
post #12 of 34 Old 02-25-2011, 05:36 PM Thread Starter
SuperRliBerty
2008 KK Liberty
Watching My wife backing in my Liberty, and I notice the left brake light was out. Here is what you will need to change the rear brake light bulb:
1 - 10 mm socket and wrench
1 - T-20 torx or star head driver
1 - 3157K bulb
Step 1. Remove the 10 mm bolts ( arrow). Gently Pull light assembly towards you.
Step 2. Remove the two torx head screws (arrow).
Step 3. Remove blown bulb, install new bulb. secure and Re-install Light assembly, steps 2 and 1.
2008 Sport Liberty
post #13 of 34 Old 02-25-2011, 06:00 PM Thread Starter
SuperRliBerty
2008 KK Liberty
If you do maintenance on your car you must have a set of torx in your tool box. Purchase the hollow point torx tips, they are for the security point torx, which are common in today's modern vehicle. Home depot (husky) has a set with handle for $8.99. harbor freight has them cheaper.
Torx (pronounced "torks") developed by Camcar Textron, is the trademark for a type of screw head characterized by a 6-point star-shaped pattern. People unfamiliar with the trademark generally use the term star, as in star screwdriver or star bits. The generic name is hexalobular internal driving feature and is standardised by the International Organization for Standardization as ISO 10664. [2] Torx Plus is an improved profile.
By design, Torx head screws resist cam-out better than Phillips head or slot head screws. Where Phillips heads were designed to cause the driver to cam out, to prevent over-tightening, Torx heads were designed to prevent cam-out. The reason for this was the development of better torque-limiting automatic screwdrivers for use in factories. Rather than rely on the tool slipping out of the screw head when a torque level is reached, thereby risking damage to the driver tip, screw head and workpiece, the driver design achieves a desired torque consistently. The manufacturer claims this can increase tool bit life by ten times or more.
Security Torx
2008 Sport Liberty
post #14 of 34 Old 02-25-2011, 09:11 PM
tjkj2002
2002 KJ Liberty
Do not use any petroleum based sprays,like WD40,on any rubber bushing or boot as it will degrade the rubber.Plus all that junk does is collect dirt and dust and wears out stuff faster.Wash with hot water and soap at least once a week is the best method.
tjkj2002 is offline
post #15 of 34 Old 03-02-2011, 05:38 PM
09_Silver
2011 KK Liberty
^^ agreed.
'11 Liberty Jet Sport - 4x4
09_Silver is offline
2008 Liberty Headlight Adjustment sbougon KK Liberty Forum 10 12-03-2013 06:02 PM
2008 Liberty Skyslider Issues JFK2218 KK Liberty Forum 39 04-05-2012 11:31 AM
which lift for 2008 liberty kk flaglfr KK Liberty Forum 0 02-01-2011 08:53 PM
2008 Liberty mods for 2011 SuperRliBerty KK Liberty Forum 5 12-03-2010 05:35 PM
2008 Liberty mechanical fan noise JWMII KK Liberty Forum 2 11-21-2010 08:09 AM
