2008 Liberty Headlight Adjustment - JeepForum.com
post #1 of 11 Old 12-07-2009, 12:30 PM Thread Starter
sbougon
2008 KK Liberty
I recently did a 2.5 inch lift on my 08 Lib. I need to adjust the headlights down some and looking at the assemblies, its hard to see how to turn them down. Any
suggestions or solutions would be appreciated.
sbougon is offline
post #2 of 11 Old 12-07-2009, 12:31 PM
Elt31987
Elt31987's Avatar
2008 KK Liberty
Ya, i was wondering the same thing, kinda feel bad for the Civic in front of me being blinded
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #3 of 11 Old 12-07-2009, 12:50 PM Thread Starter
sbougon
2008 KK Liberty
I see a small screw that has L and R markings on each assembly but looking carefully they are reversed on each side of the same screw. NO up or down adjustments seem possible.
sbougon is offline
post #4 of 11 Old 12-07-2009, 03:03 PM
diggerfreek
2008 KK Liberty
VEHICLE PREPARATION FOR LAMP ALIGNMENT
1. Check for and correct any burnt out bulbs.
2. If the vehicle is equipped with headlamp leveling, be certain that the headlamp leveling switch is in the 0 position.
3. Repair or replace any ineffective, worn or damaged body or suspension components that could hinder proper lamp alignment.
4. Verify proper tire inflation pressures.
5. Remove any accumulations of mud, snow or ice from the vehicle underbody and clean the front lamp lenses.
6. Verify that there is no load in the vehicle (cargo or passengers), except for the driver.
7. The fuel tank should be FULL. Add 2.94 kilograms (6.5 pounds) of weight over the fuel tank for each estimated gallon of missing fuel.
8. Verify correct vehicle suspension height.
HEADLAMP ALIGNMENT
NOTE: Due to the linear nature of the headlamp cutoff, a properly aimed low beam headlamp will project the top edge of the high intensity pattern on the alignment screen from the horizontal line to 50 millimeters (2 inches) below the horizontal line for domestic market vehicles, or to 125 millimeters (5 inches) below the horizontal line for export market vehicles. No horizontal (right/left) adjustment is required for this headlamp beam pattern in domestic market vehicles. Export market vehicles have a second horizontal (right/left) adjustment screw provided. The high beam pattern will be correct when the low beams are properly aimed.
1. Turn the headlamps ON and select the LOW beams for vehicles in all markets.
2. On all vehicles except those with headlamp leveling, use a screwdriver to rotate the headlamp vertical adjustment screw (2) on the back of the front lamp unit just inboard of the fender and forward of the upper radiator crossmember (1) to adjust the beam height as required.
3. For export markets only, use a screwdriver to rotate the headlamp horizontal adjustment screw on each headlamp to adjust the beam right or left as required.
diggerfreek is offline
post #5 of 11 Old 12-07-2009, 03:04 PM
diggerfreek
2008 KK Liberty
Thats just more motivation for them to move out of your way
post #6 of 11 Old 12-07-2009, 03:22 PM
Elt31987
Elt31987's Avatar
2008 KK Liberty
This is also true
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #7 of 11 Old 12-07-2009, 03:43 PM
diggerfreek
2008 KK Liberty
This is also true
You otta get some HID and see what happens to them
It's goes a little something like this:
post #8 of 11 Old 12-07-2009, 04:24 PM
Elt31987
Elt31987's Avatar
2008 KK Liberty
LMAO, first there scared, then they cry then they just drool from the brain damage.
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #9 of 11 Old 12-07-2009, 04:29 PM
diggerfreek
2008 KK Liberty
Yep, their scared because they don't know what behind then, then they cry because their eyes are burning and then it's total brain damage
post #10 of 11 Old 12-07-2009, 05:14 PM Thread Starter
sbougon
2008 KK Liberty
Got it. perfect adjustment. Thanks all.
sbougon is offline
post #11 of 11 Old 12-03-2013, 06:02 PM
quadracer512
2009 KK Liberty
Thanks for the post. I did a 2.5" Day Star and 245/75R16 Goodyear Wrangler Authorities. I've been blinding ppl for three months now. 9/32 socket and a lil trial and error and Walla. No more blinding lil ol ladies in line at the tastee freeze.
quadracer512 is offline
Parking Brake adjustment '08 Liberty 08liberty KK Liberty Forum 25 09-19-2017 11:50 AM
Liberty Gas Mileage jeepkid60 KK Liberty Forum 63 11-29-2010 01:12 PM
15's on an 08 Liberty>?? CoachRamirez KK Liberty Forum 2 02-06-2010 10:28 AM
2008 Sport Liberty squeling when turning amike_321 KK Liberty Forum 6 01-19-2010 06:53 AM
2008 KK lift? GilNewJeeper KK Liberty Forum 6 01-05-2010 08:19 PM
