2008 Liberty Changing the Oil Pan - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KK Liberty Forum > 2008 Liberty Changing the Oil Pan
PANDEMIC-USA 50" Double row LED LIGHT BAR!! These thiIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 07-27-2015, 10:43 PM   #1
cszalai
2008 KK Liberty
I hope someone can give me some guidance..... I was trying to change the oil pan on my 2008 Liberty (It has a rust hole), It looks like the pan will come right out, but the tranny is in the way. So if I just pull the motor mounts and put a 2x4 under the bell housing will the engine come up enough to clear the transmission? Or is there a easier / Better way to raise the engine / transmission (I need it up about 4 to 6 inches)
Thank You in advance
cszalai is offline   Reply With Quote Quick reply to this message
