2008 KK Coolant drain - help please!!!!! - JeepForum.com
post #1 of 2 Old 07-29-2014, 05:53 AM Thread Starter
hvteng
Hi all,
I have 2008 KK Limited Petrol Auto.
My first question is what position should the petcock plastic tap be when open? In-line with the drain nozzle or 90 degrees away from the drain nozzle?
Secondly where is the cylinder block drain plug? I found a plug on the first manifold (maybe) comes of the big radiator hose at the lower/RH of the radiator facing rear. It is just above the front diff. The plug can be removed with a 8mm L-allen key. I believe it is at position 3 (see diagram).
How much coolant should be coming out from the radiator and the cylinder block?
Many thanks.
hvteng is offline
post #2 of 2 Old 08-03-2014, 09:42 PM
kiwi_outdoors
2008 KK Liberty
engine plug
from my very terse CD-ROM manual, for a 2008 3.7L V6 KK I USA. The manual referred to plugs in the plural, being a "V" engine, that might make sense. One each side.
1997 XJ, automatic, stock 4x4
2008 KK Sport 6 speed, stock 4x4
kiwi_outdoors is offline
