2008 Jeep Liberty making noise only when I'm off the gas - JeepForum.com
post #1 of 3 Old 08-06-2011, 07:53 PM Thread Starter
lancethedance
About two days ago my Jeep started to make noise. From the inside it sounds like a knock and it sounds like its coming from the back of the truck. When you roll the window down you can hear what can be best described as a creaky squeaky type sound which sounds like its coming from the back. The noise goes away though at the slightest touch of the gas. Can anyone give me an idea of what this might be? 08 Jeep LIberty sport 36000 miles.
lancethedance is offline
post #2 of 3 Old 08-06-2011, 10:51 PM
richd
2008 KK Liberty
From what your describing,I would check your rear U-Joint.Most of the time when you have a bad U-Joint,it will make noise with gas off,and go away with acceleration.
richd is offline
post #3 of 3 Old 09-28-2012, 06:54 PM Thread Starter
lancethedance
Solution
It ended up being that all the lugs on the driver side rear tire were loose, back to a smooth ride!(I found this out days later but figured Id post it now in case someone else has a similar issue)
2008 Jeep Liberty - Whining Noise and Rattle in Engine Bay Meno19 KK Liberty Forum 6 12-18-2011 07:19 PM
2008 Jeep Liberty Wiring jpenrose64 KK Liberty Forum 0 07-21-2011 08:19 PM
2008 Jeep Liberty Fan doesn't work golfcaddie99 KK Liberty Forum 5 04-23-2011 11:21 PM
2008 Jeep Liberty Manual Transmission SuperRliBerty KK Liberty Forum 1 02-10-2011 02:10 PM
2008 Liberty mechanical fan noise JWMII KK Liberty Forum 2 11-21-2010 09:09 AM
