2008 Jeep Liberty Fan doesn't work - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KK Liberty Forum > 2008 Jeep Liberty Fan doesn't work
Unread 04-14-2011, 06:02 PM   #1
golfcaddie99
2008 KK Liberty
The fan for hvac or heat doesn't blow at all. I've checked fuses and I've researched earlier models with same symptom to look at the resister pack behind the glove box.
However looking behind the glove box I see a part that resembles the earlier models but it says do not remove.
Anyone have any ideas? Led lights for defrost, ac work. Just when I turn the knob for the fan nothing happens.
Want to know if this is something I can fix first easily before taking back to a dealership. Thanks in advance.
golfcaddie99 is offline   Reply With Quote Quick reply to this message
Unread 04-21-2011, 02:32 PM   #2
Elt31987
Elt31987's Avatar
2008 KK Liberty
Any ideas anyone?
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline   Reply With Quote Quick reply to this message
Unread 04-21-2011, 05:58 PM   #3
golfcaddie99
2008 KK Liberty
Well I bought the fan blower resistor from a Jeep dealership and followed instructions. Disconnected and isolated negative battery cable. Don't have an ohm meter so I couldn't check continuity. Went ahead and replaced the resistor part and still no fan. So I'm back to square one.
Guess I'm headed to the dealership to pay to have them diagnose.
Would still appreciate any insight anyone may have on this issue.
Thanks
Unread 04-21-2011, 10:26 PM   #4
richd
2008 KK Liberty
Thanks
Sounds like a bad blower motor.Let us know what they find.
richd is offline   Reply With Quote Quick reply to this message
Unread 04-23-2011, 09:17 PM   #5
golfcaddie99
2008 KK Liberty
richd - it did turn out to be the fan blower motor. $260 bucks to get it replaced at the dealer.
case closed on this one.
I have a brand new blower resistor if anyone wants to buy it... :-)
Unread 04-23-2011, 11:21 PM   #6
richd
2008 KK Liberty
Glad you got her fixed up,as far as resistor,I would keep it because it seems to go a lot on the Jeeps.Thanks for letting us know what the fix was,Good Luck.
