2008 Jeep Liberty drivers side rear blinker not working. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KK Liberty Forum > 2008 Jeep Liberty drivers side rear blinker not working.
Savvy Billet LED Tail LightsRough Country Jeep Suspension Deals at Rockridge 4WD!Alloy usa heavy duty ball joint kits
Unread 07-18-2014, 04:13 PM   #1
Jeep1530
Changed bulb and circuit board and still nothing. Bought a test light and I'm not get any power to that bulb.
Check to see if I was getting power to the plug by testing the wire going into and nothing.
To make sure I was checking it right I tested the passenger side and it was working at it should.
Front blinker works and the turn indicator on the dash works but clicks fast as if the bulb is blown.
Checked fuses and it has one for the left and right and both are good.
Check light with hazards on and it's only the one light not flashing.
I was thinking that if it was the lever on the column it wouldn't let neither front or back work on that side.
Any suggestions?
Jeep1530 is offline   Reply With Quote Quick reply to this message
Unread 07-19-2014, 04:43 AM   #2
Drednot
Well you've checked all the obvious stuff. Now you need to trace the harness looking for breaks or corroded connectors.
Do you have factory or aftermarket trailer lights?
91 YJ Sahara, 4.0L, AX-15/NP231, D30/D35
12 Cherokee 4x4,3.7L,
"Non Vi Sed, Arte"
Drednot is offline   Reply With Quote Quick reply to this message
Unread 07-19-2014, 06:21 AM   #3
Jeep1530
It has trailer lights but I also checked before the connection. The blinker isn't working on the trailer lights either. Will that wire be the only one with that color combination in the wiring harness that runs to the fuse box? Electrical just isn't my thing but I'll never figure it out until I just jump in and do it.
Unread 07-19-2014, 11:10 AM   #4
avatr
2012 KK Liberty
sounds like one of the bulbs are bad. have you tried swapping in a good one for the front and back?
avatr is offline   Reply With Quote Quick reply to this message
