2008 driver side door hinge issue - JeepForum.com
post #1 of 20 Old 03-21-2013, 01:33 PM Thread Starter
dpa43
2008 KK Liberty
I have never seen anything like this before on any other vehicle but there seems to be an issue with the lower driver side door hinge. The small metal piece with the spring behind it which holds the door open half way and all the way somehow has now exceeded its opening limit. If I open the door all the way the bar exceeds its limit and will not let me close the door till I push the bar back into place behind the round piece. Here is a picture of the part.
The Fleet:
2008 Jeep Liberty,2010 Ford Fusion
2007 Chrysler Sebring, 2000 Ford Windstar
1999 Ford Contour SVT
dpa43 is offline
post #2 of 20 Old 03-21-2013, 02:56 PM
HSOUSA
2012 KK Liberty
I don't know what to tell you.. Not sure if the hinges are sold separately.
What I can add to this is my '12 jet makes a 'clunk' sound once a while when opening the driver or passenger front doors. I don't know if it could be the cold or what.
HSOUSA is offline
post #3 of 20 Old 03-21-2013, 03:00 PM
brunolambert
2008 KK Liberty
I have a not so similar issue on my passenger door. Mine does not exceed the limit but the cylinder it doesn't turn anymore, so I have a metal to metal noise. I am wondering if I need to fix it before it gets a bigger problem like yours.
brunolambert is offline
post #4 of 20 Old 03-21-2013, 03:38 PM
rescue575
2011 KK Liberty
Mine do the same often. Almost feels like it is out of alignment when moving the door.
2011 Liberty Sport
2 KC Slimlite[RIGHT] 130 Watt Long Range on JK Bar
TMS Aluminum Roof Rack Cross Bars
Cobra 75, Firestik Door Jam Mount, HD Spring, 2Ft Firestik
Dunlop Fierce Attitude M/T
rescue575 is online now
post #5 of 20 Old 03-21-2013, 03:51 PM
HSOUSA
2012 KK Liberty
Have you noticed if its more common in the colder months? I've only owned my lib since January.
HSOUSA is offline
post #6 of 20 Old 03-21-2013, 04:22 PM
rescue575
2011 KK Liberty
I have only started noticing it this past couple months so I can't really compare it at this time. But obviously been doing it in the cold.
2011 Liberty Sport
post #7 of 20 Old 03-21-2013, 08:59 PM Thread Starter
dpa43
2008 KK Liberty
I believe that was how mine started out. I tried lubricating it with WD-40 but that only lasted so long, the white lithium greese keeps its quite but the damage is already done.
dpa43 is offline
post #8 of 20 Old 03-22-2013, 04:15 AM
rescue575
2011 KK Liberty
Great something to look forward to.....just as soon as warranty expires I bet.
2011 Liberty Sport
post #9 of 20 Old 03-23-2013, 08:26 AM
brunolambert
2008 KK Liberty
That is a really good thing to know. With summer comming by I'll made sure to remove all doors and check if these bastards are moving enough and see what I can do if not.
I tried to make it move last summer with my father in-law without removing the door with no luck. an hour and a half just hitting the damn thing. lot's of Jig-A-Loo but nothing out of it.
post #10 of 20 Old 03-23-2013, 09:00 AM
atwrk
2012 KK Liberty
Yup, my 2012 does the same thing. I have had it a little over a month now, and just started noticing the "clunk" when opening or closing the doors.
I'm where?
atwrk is offline
post #11 of 20 Old 03-23-2013, 10:20 AM
griffdiz
2012 KK Liberty
My 08 started getting the clunk sounds this winter too. Wd40 helps for a short time.
griffdiz is offline
post #12 of 20 Old 03-23-2013, 10:36 AM
HSOUSA
2012 KK Liberty
Can anyone recommend a good grease to use on the hinges? Wd-40 will dry up quick
HSOUSA is offline
post #13 of 20 Old 03-23-2013, 10:55 AM
mjcougler
2015 WK
Door hinge "clunk"
First of all, both door hinges need a good squirt of oil every six months. When you first hear the clunk, it is saying "oil me!".
I have 10w30 motor oil in a goose-neck oil can that I use. Oil the roller and then oil both pivot parts of the hinge pivot pin in such a way that the oil flows down onto the pivot pin. Stuff a rag in there under the two hinges if you are a clean freak to catch the excess flow.
This roller looks worn out. Yes, in my opinion, it needs to be replaced ASAP.
my $.02
Mike Cougler
15 Jeep GCL; 11 Jeep CL; 67 Jeep M725 Ambulance;
04 Ram 2500 CTD; 46 Willys CJ2A
mjcougler is offline
post #14 of 20 Old 05-22-2013, 08:58 AM
louder1
2008 KK Liberty
My wife's 08 driver's side is the same. I'm trying to find out if there are replacement parts. There was a video on how to replace just the pins but it was on a chevy truck. Similiar process as in you need to compress the spring and knock out the pin to get to the bushing. He held the door in place with a homemade wooden brace and jacked up after removing the hinge bolts.
louder1 is offline
post #15 of 20 Old 07-28-2015, 10:35 AM
grizzlyman
2008 KK Liberty
mine just did the EXACT same thing ad the original poster- exceeded the limit.I keep a screwdriver in the door pocket to pop it back in. Upon further inspection this is not a problem with the little cam spring thingy or the rolling bushing, its a problem with the hinge. The hinge is supposed to limit the range of opening, and it's opening too far. The little cam thing does not have anything to do with this. There is a little tab on the hinge which stops the other part of the hinge from moving further than it should. The tabs are intact, so my hinge somehow got either bent, or is angled on the frame not plumb. I'm not sure which. I will post a remedy when I have it fixed.
grizzlyman is offline
