2 wd or 4 wd - JeepForum.com
post #1 of 23 Old 04-03-2014, 03:20 PM Thread Starter
avatr
2012 KK Liberty
2 wd or 4 wd
I'm curious - how many 2 wheel drives vs 4 wheel drives are on here? if you have a 2 wd, have you lifted it? more aggressive tires? drive it on the beach or off-pavement?
avatr is offline
post #2 of 23 Old 04-03-2014, 03:53 PM
nfodzy
2011 JK Wrangler
Not bashing anyone that drives a 2 wheel drive, but I don't see the point of it. If you want it, buy a car or van. Generally when you're buying a vehicle with more ground clearance, it's best to get it with 4 wheel drive.
nfodzy is offline
post #3 of 23 Old 04-03-2014, 04:49 PM
BillyP
4WD here - not allowed to take a 2WD on any of the beaches around here (NC coast.)
BillyP is offline
post #4 of 23 Old 04-03-2014, 04:55 PM
LKWJEEPER
2009 KK Liberty
Don't the 4wd and 2wd have the same clearance? Also unless you have select trac your in 2wd all the time.
I bought 4wd because I want to wheel it and not because I need it.
Sent from AutoGuide.com Free App
LKWJEEPER is offline
post #5 of 23 Old 04-03-2014, 10:24 PM
taylorgrandorf
2008 KK Liberty
I have a 2WD (High School Graduation gift) and I have the JBA 2.5" lift kit on it, as well as running boards, the Jet headlights, and a Steelcraft Bull Bar. Since I am still on my parent's insurance, and they would kill me if I took it off roading (still want too) the lift was mostly because I needed a new suspension anyway and like the look better. Regular Limited Edition 17" wheels and tires.
taylorgrandorf is offline
post #6 of 23 Old 04-04-2014, 02:06 AM
Bmxer524
2011 KK Liberty
They should. They measure ground clearance from the lowest point, which on any vehicle with solid axles(unless you're running portals....) is the diff.
Technically the only way to gain more is going up in tire size(every 2" you go up in diameter, you gain an inch or lift/ground clearance for the axle), which leads to suspension/body lifts to fit the larger tires. Lifts only help run larger tires and help get ground clearance on the body and chassis.
Anyways, on topic, I have 4wd. Command-trac to be exact. It wouldn't be a Jeep without 4wd
2011 KK - Skyslider - JBA Adjust-A-Strut - OME 731 - Bilstein Shocks - JBA UCA- 245/75-16 Duratracs
Bmxer524 is offline
post #7 of 23 Old 04-04-2014, 04:01 AM
LKWJEEPER
2009 KK Liberty
I owned a 2wd Jeep. Funny though. I bought it brand new at a Jeep dealer :-p
post #8 of 23 Old 04-04-2014, 02:05 PM
brunolambert
2008 KK Liberty
That is not true. When you have select track it's 2wd unless you flip the switch, just like command trac.
Sent from my Nexus 5 using JeepForum
2008 KK Sport, Light Graystone Pearlcoat, Selec-Trac II, tow package, Firestone Destination LE2
brunolambert is offline
post #9 of 23 Old 04-04-2014, 02:05 PM
mrbeal
2011 JK Wrangler
A friend of ours has a 2WD Jeep Grand Cherokee. It's several years old and watching her try to drive up our snow/ice covered driveway cracked me up. She got to a point that she was sliding backwards and all I could think to myself was "hurry up and pull the 4X4 lever up so you can drive up my driveway". Well, she didn't pull the lever up because there wasn't one. When she got out of the Jeep I asked her about it and that's when she told me that her husband bought it for her when they were in Texas and in Texas you don't need 4x4 so the Jeep dealers sell a lot that aren't because they are so much cheaper. So, lesson learned... if you buy a Jeep down south leave it down south when you move to New England.
BTW, mine is 4WD, I wouldn't have it any other way.
mrbeal is offline
post #10 of 23 Old 04-04-2014, 02:16 PM
LKWJEEPER
2009 KK Liberty
What I meant was the majority of the KK owners have Command trac which is 2wd unless you flip the switch to 4wd. To use 4wd with Command Trac you have to be on loose terrain.
I meant people with Selec Trac can run 4wd all day with no problems.
So majority of us stay in 2wd all the time unless we are wheeling or conditions call for it. I've actually needed 4wd once for the first time in my life this past Winter. It handled beautifully.
post #11 of 23 Old 04-04-2014, 02:21 PM Thread Starter
avatr
2012 KK Liberty
Originally Posted by mrbeal View Post
.... and in Texas you don't need 4x4 so the Jeep dealers sell a lot that aren't because they are so much cheaper. So, lesson learned... if you buy a Jeep down south leave it down south when you move to New England......
yep - most around San Antonio are 2WD, rarely see a 4WD. I never heard of the Sky Slider roof either. that must be a northern thing. of course it gets so hot 8 months out of the year - you'd never have it open.
bmxer - It wouldn't be a Jeep without 4wd ..... that's not what my VIN says....
avatr is offline
post #12 of 23 Old 04-04-2014, 02:39 PM
taylorgrandorf
2008 KK Liberty
Mine had the Skyslider - I bought it used but the CarFax shows the original dealer as Houston. They're just very rare.
post #13 of 23 Old 04-04-2014, 02:52 PM Thread Starter
avatr
2012 KK Liberty
cool! I shopped for 6 months craigslist, local dealers, AutoTrader and Carmax - never saw one.
avatr is offline
post #14 of 23 Old 04-04-2014, 02:58 PM
taylorgrandorf
2008 KK Liberty
It's a good thing and a bad thing - I just dropped $3000 to get it fixed
post #15 of 23 Old 04-04-2014, 03:18 PM Thread Starter
avatr
2012 KK Liberty
ouch!!
avatr is offline
