08 Liberty Turn Signal Switch Dims Dashboard - JeepForum.com
post #1 of 8 Old 02-21-2013, 01:48 PM Thread Starter
MikeFinn
1995 XJ Cherokee
My wife's 08 Liberty Sport has an issue when I use the right turn signal.
When signaling to the right, it dims the dashboad and radio lights, and shuts off the Fog lights (if turned on) until the turn signal switch is returned to the center.
This also occurs while using the right passing signal (3 flashes) feature as well.
If I slighly move the switch slightly to where it just makes contact, there are no issues.
This leads me to believe that the turn signal switch is faulty and needs to be replaced.
I have searched around and found a couple replacement switches online but wanted to check to see if anyone else has experienced this or has any other thoughts / recommendations.
http://www.rockauto.com/catalog/more...477&cc=1441543
Best -Mike
MikeFinn is offline
post #2 of 8 Old 02-21-2013, 07:36 PM
BillyP
I just replaced my switch. Got it from the local NAPA... they had to order (came in next day) for $68 with shipping and tax. Takes about 15 minutes to install.
BillyP is offline
post #3 of 8 Old 02-22-2013, 07:31 AM Thread Starter
MikeFinn
1995 XJ Cherokee
Hey Billy thanks for the reply. It looks like a simple swap out with acouple T20 screws. Did your switch have a similiar failure?
95 Cherokee 3" Lift 31X10.5's (deceased)
91 Cherokee 5-Speed 3" Lift 31X10.5's
08 Liberty Sport
12 Liberty Latitude
MikeFinn is offline
post #4 of 8 Old 02-22-2013, 09:33 AM
BillyP
No, not the same failure. My signal would randomly flash the opposite direction than it was switched too. That and flash 3 times in the opposite direction when it canceled... had done that since I bought the car new. Crazy!
BillyP is offline
post #5 of 8 Old 04-25-2013, 07:18 AM Thread Starter
MikeFinn
1995 XJ Cherokee
New switch, solved the problem! Easy swap. Thanks for all the info.
08 Liberty Sport
12 Liberty Latitude
MikeFinn is offline
post #6 of 8 Old 04-25-2013, 01:21 PM
BillyP
Glad it worked out for you!
BillyP is offline
post #7 of 8 Old 06-17-2014, 10:10 PM
SloJeeper
2008 KK Liberty
Sorry to resurrect this from the dead
but my Liberty does the same thing.. did the switch fix your problem?
Thanks
SloJeeper is offline
post #8 of 8 Old 06-18-2014, 09:36 AM
BillyP
The new switch fix the problem and is still holding up over a year later.
BillyP is offline
