08 liberty stuck in 4WD - JeepForum.com
post #1 of 14 Old 08-09-2010, 09:18 AM Thread Starter
bigworm36
2011 JK Wrangler
So I accidently spilled some water on my 4WD switch in the middle area by the gear shifter. Ever since that happened I noticed that the 4WD drive light came on and the service 4WD light came on. So basically my car was in 4WD even though my switch was in 2WD. I tried switching it back and forth but nothing. I know it was in 4WD cause I could feel the difference when I made turns. So I had to drive home from a concert that was 2 hours away with this thing in 4WD which 90% was on a highway going 75. but when I got home and turned the car off and then turned it back on everything was back to normal. So my question is do you think I could have messed anything up on the 4WD system driving the car like that. I tried to go easy on the turns cause I know thats not good for it when its not a slippery surface.
1st- 1994 Jeep Cherokee
2nd-2000 Jeep Cherokee Sport
3rd- 2008 Jeep Liberty Unlimited 2.5 JBA Lift, 32" goodyear duratracs
Current- 2011 Rubicon Unlimited
bigworm36 is offline
post #2 of 14 Old 08-09-2010, 09:33 AM
Elt31987
Elt31987's Avatar
2008 KK Liberty
2 Hours is a long time driving in Part Time, but at least most of it was highway so it wasn't sharp turns. Its possible the Transfer Case could have been damaged, but if most was highway there's a much better change you didn't break anything.
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #3 of 14 Old 08-09-2010, 09:58 AM Thread Starter
bigworm36
2011 JK Wrangler
You think I should take it to the dealership and have them look at it. I dont know how much they can do without opening anything up?
post #4 of 14 Old 08-09-2010, 10:03 AM
Elt31987
Elt31987's Avatar
2008 KK Liberty
If the dealership will look at it for free(which i doubt) and your not covered under a warranty i would do it. If your under a warranty, telling them you drove on dry ground for that long will give them a good reason to try and void your warranty.
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #5 of 14 Old 08-09-2010, 10:36 AM Thread Starter
bigworm36
2011 JK Wrangler
Its still under warranty for 6000 more miles. Everything seems good. I guess Ill just forget about it and hope that nothing happens in the upcomming years. Thank you for your help!
post #6 of 14 Old 08-09-2010, 11:42 AM
VMF
2008 KK Liberty
well the chain can b stretched and can/will slip eventually. there are rebuilt kits or remanufactured T-cases for our cars out there, will b much cheaper then servicing it at the dealer. should not take to replace it as well. i say 2 hours if u have another person to help
___________________________
2008 KK limited 4x4. Inferno Red
2009 JK Rubicon. Black
2004 UCF31. Black
2001 EM2. Inca pearl
2012 UD Limited. Royal Gray
VMF is offline
post #7 of 14 Old 08-09-2010, 07:07 PM
Dave_B
2008 KK Liberty
First off, what transfer case do you have? I have run my select-trac at 75-80 for hours,no problems.
Dave
Lovin' my CARBON FOOT PRINT!
Dave_B is offline
post #8 of 14 Old 08-09-2010, 07:23 PM Thread Starter
bigworm36
2011 JK Wrangler
I don't think I have select track it's 4 wheel lock
post #9 of 14 Old 08-09-2010, 07:27 PM
Elt31987
Elt31987's Avatar
2008 KK Liberty
Command Trac if its "Lock" and especially if you could feel something awkward when turning
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #10 of 14 Old 08-09-2010, 09:28 PM Thread Starter
bigworm36
2011 JK Wrangler
Yup that's what it was
post #11 of 14 Old 08-09-2010, 10:00 PM
tjkj2002
2002 KJ Liberty
Spilling water on the switch makes this issue your fault,it is fraud if you try and get it warrantied and why parts and new vehicles are so expensive(fraudulent warranty claims).
Driving for that long and fast in part time 4wd has caused damage to your t-case,it may or may not last much longer,better change the fluid just to be safe but yo will have issues sooner or later.Even if going straight you still have binding going on since your front and rear diffs are geared just a tad different,turning or not turning has the same binding but you just feel it more when turning.
tjkj2002 is offline
post #12 of 14 Old 08-10-2010, 05:00 AM
daggo66
2009 JK Wrangler
OMG, exactly what damage has he done to his TC and how do you know without seeing it? Chances are the water shorted out the switch and it wasn't even in 4WD. The binding/wheel hop that occurs from driving in 4wd on pavement will grenade your differential long before it harms the TC.
Tom
daggo66 is offline
post #13 of 14 Old 08-10-2010, 08:19 AM Thread Starter
bigworm36
2011 JK Wrangler
First of all I never said I was going to try and get it warrantied. If you read my second response I was not going to do anything and just hope no major damage was done. but it was in four wheel the whole way home for sure
post #14 of 14 Old 08-11-2010, 11:56 AM
KUHawkhead
2008 KK Liberty
I SERIOUSLY doubt you hurt it. If you did, the vehicle wasn't made to be driven the way Jeeps are driven anyways.
I would take it in, tell them the problem, and leave it at that. It's a new vehicle for goodness sake.
KUHawkhead is offline
snorkel for liberty kk david1980 KK Liberty Forum 6 05-03-2013 08:28 AM
5W-40 on Liberty KK 3.7 nkanakakis KK Liberty Forum 6 11-02-2010 01:35 PM
Should I get a Liberty? kinsale KK Liberty Forum 13 10-31-2010 05:49 AM
Liberty KK TSB List Elt31987 KK Liberty Forum 1 07-25-2010 07:04 PM
15's on an 08 Liberty>?? CoachRamirez KK Liberty Forum 2 02-06-2010 10:28 AM
