08 Liberty Rough Idling in "Drive" - JeepForum.com
post #1 of 5 Old 08-14-2011, 04:25 AM Thread Starter
Luch466
2008 KK Liberty
I've noticed lately that my 08 Jeep Liberty has been rough idling while at a stop sign or intersection. It makes the car vibrate aggressively sometimes and gets really annoying. What is the cause of this rough Idling and how can I fix it?
Luch466 is offline
post #2 of 5 Old 08-14-2011, 06:45 PM
SuperRliBerty
2008 KK Liberty
I had cleaned my throttle body and replaced the stock plugs with Bosch Platinums...... rock steady idle in park, reverse or drive.
Try those.
If no CE light, the EGR and it's operation are to be checked.
2008 Sport Liberty
Cold air intake*Trush (magnaflow) turbo muffler* Hypertech power program*
Hood Prop mod. Battery Quick Release mod.
Resonator removed (sounds like a V8 on start up)
SuperRliBerty is offline
post #3 of 5 Old 08-15-2011, 12:51 AM Thread Starter
Luch466
2008 KK Liberty
Try those.
I am Coming across 2 kinds of Bosch Platinum. There is the Bosh Platinum and then Bosch Plantinum +4. What is the difference?
Luch466 is offline
post #4 of 5 Old 08-15-2011, 06:21 AM
Elt31987
Elt31987's Avatar
2008 KK Liberty
Just put in the stock NGK plus, Clean the throttle Body and Injectors, and replace air filter if over 12K with a standard FRAM Double Guard
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #5 of 5 Old 11-22-2011, 11:58 AM
dtj8995
2008 KK Liberty
had your same problem...perplexed me...turned out to be the plug coil for my cyl 4 ...25 dollars later and 5 minutes of work my issues was gone...used the same bosch plugs and everything... check the coil
dtj8995 is offline
Help: jeep liberty 2009 8" ROOF antenna NEEDED bobbarto KK Liberty Forum 25 09-09-2011 06:52 AM
Jeep Liberty 3.5" Lift SuperRliBerty KK Liberty Forum 7 02-18-2011 11:56 PM
First Drive: 2011 Jeep Liberty ( Beautiful scenic pics) SuperRliBerty KK Liberty Forum 7 01-20-2011 05:35 PM
What color "white" is my Liberty? DentonTrue KK Liberty Forum 8 11-01-2010 12:42 PM
2010 Liberty "Renegade" with Transmission Vibration davebwi KK Liberty Forum 4 08-09-2010 12:39 PM
