08 Liberty Rear Window probs - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KK Liberty Forum > 08 Liberty Rear Window probs
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 07-07-2013, 09:46 AM   #1
malt4101
Seem like this should be an easy solution, but have a weird problem. Neither of my rear windows will roll down. I have tried from drivers controls and each door with and without the safety switch engaged. Passenger window will roll down, but only from driver control too. What is really odd is that when you hold the button up, the dash lights dim for just a second, telling me that the switch is engaging the up side of the motor. Any ideas?
malt4101 is offline   Reply With Quote Quick reply to this message
Unread 07-07-2013, 02:06 PM   #2
khalilw
2011 KK Liberty
check the connectors inside the driver's door, remove door's inner panel and you will find 4 o 5 connectors next to the dashboard, don't be afraid of plug them in the wrong place because they won't plug in, they will only plug in the right hole.
You need to remove 2 screws before taking the panel out.
One of them is in the left bottom corner, its a little screw, the other one is next to the door handle, behind the plastic, remove that little panel that supports the handle and you'll be able to remove it.
With both screws removed, pull the door panel upwards and it will come out.
khalilw is offline   Reply With Quote Quick reply to this message
