08 KK Liberty COMMAND-TRAC Transfer Case capacity - Page 3 - JeepForum.com
post #31 of 49 Old 06-21-2013, 11:52 AM
Skipper6413
2011 KK Liberty
Interesting that the capacity listed is 3.9 pints but actual quantity to top off is right at around 3.9 quarts! Coincidence? Also interesting that you pull out only 2 quarts from factory fill which is 3.9 pints. Could this be a factory worker filling the fluid to "spec" versus to bottom of fill hole, and could it be a typo that they said pints when it should be quart?
If all of this speculation is true, could 4x4 libbys be at risk right out of factory?
Skipper6413 is offline
post #32 of 49 Old 06-21-2013, 04:37 PM
Ted15
2010 KK Liberty
There is a very good chance that the chain in my transfer case is stretched and that's the cause of my vibration. I'll know more after tomorrow if the new trutrac doesn't fix it. I had the same problem with the capacity issue, also with the diffs. The manual was almost a quart off for the front diff. Seems to me that the factory was cutting corners. I know for a fact that they build their cars based on 100,000 miles. They pay close attention to every step in the production process and save pennies whenever they can. I wouldn't trust the writes capacity when it contradicts the procedure, especially if it's on the short side. I'm driving around with 3 quarts for the moment but intend to top it off when I get a chance.
2010 KK Sport, Detoures Knucklebone & backbone, smittybilt XRC 10, rigid led lights, R/L sliders & rack, cb, EMT2, R/K 15x7, OME, JBA, mopar skids & hitch, headlight covers, 4.10's and TruTracs
Ted15 is offline
post #33 of 49 Old 06-21-2013, 11:33 PM
Gageraid
2008 KK Liberty
Gonna try to tackle this on my next day off.
Anyone notice any better performance after doing the T-case?
Gageraid is offline
post #34 of 49 Old 06-22-2013, 10:30 AM
Skipper6413
2011 KK Liberty
No not really.
post #35 of 49 Old 12-09-2013, 07:22 PM
Skipper6413
2011 KK Liberty
Perhaps the final note: filled up to bottom of fill hole and tcase did a "purge" of the excess. Just fill to spec amount rather than to bottom of fill hole. Must have an overpressure relief valve on it.
post #36 of 49 Old 12-09-2013, 08:11 PM
Gageraid
2008 KK Liberty
I just did mine a few months ago to where I could touch it with my fingertip.
OME lift
Hypertech Max Energy
CAI, Gibson exhaust, 4.7L throttle body
Gageraid is offline
post #37 of 49 Old 12-10-2013, 03:04 AM
Ted15
2010 KK Liberty
I topped mine off shortly after my last post. I noticed the front seal is seeping fluid. Not sure if it's related to the problems I'm having with the front axle but it's not likely. Maybe these aren't supposed to be filled all the way. If that's the case though, how does one check the fluid level?
Ted15 is offline
post #38 of 49 Old 12-13-2013, 08:44 PM
Skipper6413
2011 KK Liberty
Mine took 5 months to "purge" and leaked out probably 1/4 quart out. Not much. But then it just stopped just as quick.
post #39 of 49 Old 12-13-2013, 08:47 PM
Skipper6413
2011 KK Liberty
The tricky part is how much do you put in. The spec amount or fill to bottom of fill hole as the manual says both, but the amount isn't close to the same. The answer is to fill it to the spec amount instead. Filling to bottom of fill hole is too much.
post #40 of 49 Old 01-07-2014, 09:08 AM
54lariat
2009 KK Liberty
So I read all 3 pages
and I think Im going to go with what I take out, which I imagine will be about 2 quarts. Good read tho!
54lariat is offline
post #41 of 49 Old 01-07-2014, 09:44 PM
Poncherello
2010 KK Liberty
Originally Posted by Gageraid
Gonna try to tackle this on my next day off. Anyone notice any better performance after doing the T-case?
Gage,
Had my transfer case and axle fluids changed and noticed no change in performance. Had it down around 65k now got about 70k on it.
When you get knee-deep in a situation, floor it.
Poncherello is offline
post #42 of 49 Old 01-08-2014, 02:02 AM
Gageraid
2008 KK Liberty
Originally Posted by Poncherello View Post
Gage,
Nothing gained, but peace of mind and the knowledge to do it again or if I have to help out another Jeeper.
OME lift
Gageraid is offline
post #43 of 49 Old 08-24-2014, 08:53 PM
dtbingle
2011 KK Liberty
Just changed mine....like others, about 2 quarts out, and like 3.7 quarts in. So should this be drained to like 2 quarts'ish or is having 3.7 quarts fine (to bottom of the fill plug)?
dtbingle is offline
post #44 of 49 Old 10-03-2014, 09:47 AM
jfost2001
I just took out 2 qts and put in 2.75 qts. I was afraid of blowing seals so I stopped. I'm going to leave it at this. Should be good to go.
jfost2001 is offline
post #45 of 49 Old 09-14-2015, 09:04 AM
MarkZ28
2009 KK Liberty
Haha, you will not blow out seals with too much oil in any engine, transnfr case, or diff. The proper procedure for any transfer case, diff, or manual trans is to fill it until the fluid starts to drip out the fill hole. Even if you coukd stuff 8 quarts in the transfer case, the seals wont "blow out". The only was a seal can blow out is if theres pressure behind it, which there is not present at tge seals in drivetrain parts, un0less you drive a hydraulic powere drivetrained vehicle like a crop fertilizer tractor. Yes, the seals may leak but thats not from more pressure from extra oil. The front output seal on the transfer case and pinion seal on the diffs are under the fluid levels and seal the oil in. Old seals above the oil level may be hardened and weak/cracked which will seep oil if the level is above their level. Pressure is made by pumps, not by oil level. Its not a good idea to overfill engines or automatic trans due to oil aeration, which will kill bearings and sliding surfaces. Even if you overfill the rest it wont really gurt anything, may make a mess if it gets puked out tge vent tubes and past seals not made for being immersed in oil. Follow the recomended procedure to fill to the fill hole, thats the proper level. Even if its a pint and a half more than recomended, its still how the engineers designed it to be filled. That little bit extra, if it is too much, will not blow seals or harm anything. Id rather have a little more than recomended than be under. Oil is also used to cool parts, less oil means less cooling. Not to mention the high speed driving will cause tge oil to be flung away from moving parts, making less available in the sump to lubricate the gears, bearings, and chain. There is a pump in the case that uses oil to feed the bearings, especially the ones above the oil level. Anyway, fill the gluid level until the fluid runs out tge fill hole. It will be at the proper level for that part as the engineers designed it. Someone messed up on the spec sheet at the printing place or the guy writing the manuals was drunk that day. All sources use the specs the manufacturer gives, so if Mopar says its a certain number thats what all sources will state, even if its wrong. Clymer, Haynes, etc go by what Jeep says. Best way would be to contact tge actual company tgat nade tge transfer case and ask them, which is probably New Process, which Dodge used for their trucks and suv models.
MarkZ28 is offline
5W-40 on Liberty KK 3.7 nkanakakis KK Liberty Forum 6 11-02-2010 01:35 PM
Should I get a Liberty? kinsale KK Liberty Forum 13 10-31-2010 05:49 AM
Command Trac vs. Select Trac II sebush3 KK Liberty Forum 9 08-16-2010 07:43 AM
Why is the Sport limited to only 3500lb tow capacity? KDOG2008 KK Liberty Forum 3 06-20-2010 06:18 PM
15's on an 08 Liberty>?? CoachRamirez KK Liberty Forum 2 02-06-2010 10:28 AM
