08 KK Liberty COMMAND-TRAC Transfer Case capacity - Page 2 - JeepForum.com
post #16 of 49 Old 07-18-2011, 01:27 PM
sk1er18
2007 XK Commander
Also, my owners manual does state "fluid should be added only at the filler hole until fluid start to run out of filler hole".
My concern here is that this could be a "boiler plate" statement for the manuals and not apply to our tcases.
So it still leaves me baffled.... which is it? Lol I'm half tempted to split the difference and just throw in an extra quart of oil.....
-Matt
sk1er18 is offline
post #17 of 49 Old 07-22-2011, 03:54 PM
sk1er18
2007 XK Commander
Feel obligated to give you guys a quick update in case someone makes a decision based on my previous posts.
Had a friend in FL check with his local dealership... they all fill up to the drain plug. Today i'm off from work so I gave my dealer a call (who im on pretty good terms with since I bought 2 jeeps from them in the past year when "times were tough" for dealers in general)... called the sales guy i deal with and explained the situation since I didn't want a generic answer from the service manager thinking im not a returning customer (they piss me off ill go elsewhere ). Service manager basically said that every jeep there gets filled to the drain plug, which is what all of the service procedures state to do. He doesn't know why there's such a discrepancy in the specified fluid capacity vs what it actually takes to fill this particular T-Case but said they've never seen an issue.
Another thing that factors in for me is that I still have almost 3 years left on my warranty... and they emphatically agreed that if I have an issue with a seal blowing out or worse, that I would not be at fault because my manual clearly states to fill it up until the drain plug. As a matter of fact, my owners manual doesn't even specify a fluid capacity in it... So to be "safe" with my warranty, it's best to go by the manuals service procedure.
The result: I put another 1.5+ quarts in (yup, took a little over 3.5 total like other members have claimed) and im not going to think about it anymore
-Matt
sk1er18 is offline
post #18 of 49 Old 07-30-2011, 09:50 PM
GearGuy10
Figured I'd add my experience to this mystery...I just did the diffs and transfer case on my wife's KK tonight. First change at 32k. Exactly 2 quarts of fluid came out of the transfer case. I re-filled it with exactly 4 quarts, to the fill hole.
Sounds to me like the transfer case will hold 2 to 4 quarts and the manufacturer is filling it to the low end to save some money.
HIS: 1998 Cherokee Sport Chili Pepper Red-SOLD
DrawTite front hitch
HERS: 2009 Liberty Sport Light Graystone Pearl
100% Stock
GearGuy10 is offline
post #19 of 49 Old 08-05-2011, 07:08 AM
stumpers54
2009 KK Liberty
Based on my earlier post and those sumitted after, I thought I would try something.........During an oil change, I decided to pull 1.5 quarts from the T-Case which would bring the volume to about 2.3 quarts, close to what the fill volume was from the factory. I then proceeded to go up North for the weekend with boat in tow. Periodically, during highway operations, my ESP and Svc 4WD warning lights would display to include turning off the ESP. This happened roughly 6 times and lasted for about 15 minutes or so. No detectable operating impacts were noted. Shortly after returning, I stopped by Advance Auto and had them scan for historical fault codes and none were present. I topped off the T-Case to the fill hole with about 1.5 quarts and towed the boat the following weekend with no warning lights ever illuminating........I suspect the lights/ESP off issue I experienced was somehow related to heat build up due to low fluid fill, although I don't know if there is a T-Case temp sensor............8/10/11. Just got back from towing the boat with two Yaks on the roof. Even with the T-Case full and using the tow/haul mode, the same issue returned. I am at a loss to figure this out, looks like I may have to take it to the dealer.
stumpers54 is offline
post #20 of 49 Old 01-21-2013, 12:44 PM
DanFxr
2010 KK Liberty
Transfer Case volume 2010 Lib
Just changed the fluid in my transfer case. About 2 quarts came out. I can not find the refill capacity in the owners manual or online. I put 2 quarts back in however it does not come out of the filler port. Is there any update to the correct volume. Thanks
DanFxr is offline
post #21 of 49 Old 01-22-2013, 08:53 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Taken from the 2008 KK FSM:
Transfer Case - capacity
♦ MP1522 1.9 Quarts 1.8 Liters
♦ MP3022 2.0 Quarts 1.9 Liters
♦ Approximate dry fill or fill to bottom edge of fill plug hole.
CAUTION: Nominal refill capacities are shown. A variation may be observed from vehicle to vehicle due to manufacturing tolerance and refill procedure.
JeepCares is online now
post #22 of 49 Old 01-22-2013, 05:33 PM
AtTheHelm
Yeah same happened to me, about 2qt came out but it took almost 4 qt to fill to the plug. Apparently it comes out the breather hose when you fill to the plug.
I adjusted back to 2 qts...
AtTheHelm is offline
post #23 of 49 Old 01-22-2013, 05:35 PM
AtTheHelm
Thanks for commenting but there is no way there is that much variation in machining/casting tolerances.
post #24 of 49 Old 01-27-2013, 07:35 PM
27tubguy
2008 KK Liberty
anbody have the exact fill amounts on all fluids??
Im trying to change out all fluids stem to stern anyone got the real world fills, for front diff(dana 30) rear (8.25) tranny, transfer on an 08 KK.
Morgan, Im listening...lol
Richie from Boston
27tubguy is offline
post #25 of 49 Old 01-27-2013, 09:17 PM
AtTheHelm
If i remember correctly...
Front: 80w 90 GL5 little under 2qts, to fill plug
Tcase: ATF+4 I ended up going with 2qts at the recommendation of a reputable lost member.
Rear: 75w 140 synthetic, about 2.25 qts, to fill plug (stock diff cover)
Coolant: must be mopar hoat or zerex G05 (valvoline product) 14qts
post #26 of 49 Old 01-27-2013, 09:19 PM
AtTheHelm
Highly recommend dealer for the transmission fluid change though unless you want to buy the $60 dipstick and a scanner that reads real time trans temp.
post #27 of 49 Old 04-18-2013, 07:17 AM
x99j
did you experience this? i got 4 quarts in mine and seems to be alright?
06 kj 3.7l, 6speed manual, np241 command track
91 yj 2.5l, ax-5, np 231 3 inck lift, 31'' mud rovers
12 kk 3.7L, 42rle, mp1522, d-30, 8.25.
x99j is offline
post #28 of 49 Old 06-19-2013, 10:37 PM
Skipper6413
2011 KK Liberty
Glad I found this post so Im not the only one who discovered this. I bought three quarts to make sure I had enough fluid and lo and behold I was still short of "top off." From the trail of posts, Im leaving it at three quarts.
Skipper6413 is offline
post #29 of 49 Old 06-21-2013, 09:37 AM
carlosburitica
2010 KK Liberty
1 qt= 2pint
so when they say that it takes 3.9 pints they are talking about 2qt.
carlosburitica is offline
post #30 of 49 Old 06-21-2013, 09:44 AM
carlosburitica
2010 KK Liberty
some people recommend mineral vs synthetic oils for the differentials, some aftermarket differential companies write "do no use synthetic", reason is that the diff. are splash lubricated a totally different system that the engine and transmission
5W-40 on Liberty KK 3.7 nkanakakis KK Liberty Forum 6 11-02-2010 01:35 PM
Should I get a Liberty? kinsale KK Liberty Forum 13 10-31-2010 05:49 AM
Command Trac vs. Select Trac II sebush3 KK Liberty Forum 9 08-16-2010 07:43 AM
Why is the Sport limited to only 3500lb tow capacity? KDOG2008 KK Liberty Forum 3 06-20-2010 06:18 PM
15's on an 08 Liberty>?? CoachRamirez KK Liberty Forum 2 02-06-2010 10:28 AM
