KPalm7 LJ Jeep Registry
Previous Jeep LJ Wrangler Next Jeep
KPalm7 LJ
Email Bookmark Print
Jeep Information
Model:LJ Wrangler Unlimited Sport
Engine:4.0 I6 Supercharged
Transmission:NSG370, tucked as close to the tunnel as she'll go!
Transfer Case:NP231, SYE, Novak Cable shifter
Front Axle:HP44 1/2"wall, Yukon Zip Air Locker, Chromo Shafts, Chevy machined flat-top knuckles, Parts Mike Hi-steer arms, drilled and slotted rotors, warn hubs, one ton TREs with custom hi-steer, Saginaw frame modification with rebuilt drilled and tapped Durango box, old red skyjacker t-case drop is now the truss
Rear Axle:Dana 44 with Eaton E-locker and chromos, all new mounts.
Axle Gear Ratio:4.88
Suspension:Skyjacker Coilovers up front with wristedFord radius arms, custom rear long-arms on coils with limit straps
Tires:37x13.50r17 Toyo Open Country MTs
Armor:Custom full fenders, full flat-skid, smitty sliders, Front Genright stubby, Rear Shittybilt Clasic swing-out tire carrier
Recovery Gear:10k Ramsey Worm Drive, shackles, hi-lift
Accessories:Lotsa LED lights, sanden OBA, HPTuner tuning, fancy switches
Future Modifications:More underarmor, roll-cage, new rear end setup.
Login Or Register To Post Comments
View kpalm7's Jeep
12-22-2015, 11:40 AM
Man these are some old pics. Before I had any flex whatsoever... back when I had mismatched gear ratios (4.11 in front with a detroit locker, 3.73 in the rear with e-locker), cruddy low-steering, no armor to speak of. Well, she's come a long ways:
And this was before the supercharger or 37s, but I at least get some flex now... Still not enough to keep all four tires on the ground though.
