Ok so i just recently bought a 1997 tj wrangler test drove it and it rode great, the things is i didnt think to turn on the headlamps because it was around 3pm. It turns out my headlamps dont work at all. Low beams or brights. The brights indicator doesnt even show on the dash, but all others do. Also, all my other lights work just fine.
If the fuse is good, try to jumper the bulbs to test them or just measure continuity to make sure they aren't burnt out. If that passes, it could be a bad switch at the steering column especially if the PO used higher wattage lights without a relay harness upgrade...
Sent from my HTC6500LVW using Tapatalk
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
