Wrangler Jeep Registry
Previous Jeep TJ Wrangler Next Jeep
Wrangler
Email Bookmark Print
thchannell
Litchfield
Jeep Information
Year:2003
Model:X
Turn on the key, dashlights work, door open beeps...try to start. Nothing!
None
Login Or Register To Post Comments
TreyE15
View TreyE15's Jeep
04-08-2013, 03:48 PM
I had a problem a little similar. My ignition acutator broke in my column. The first two time all power would come on but would not turn. Then it broke completely on the third try. If you take it to the shop they will tell you that you need a new column. If that's the problem. Take your column apart and make sure your actuator isn't sheared or broken. If it is I can share a website that can help you replace the part and not the column.
-Trey
