swap out from rusted to not so rusted frame Jeep Registry
Previous Jeep TJ Wrangler Next Jeep
Email Bookmark Print
charies
harveys lake
Jeep Information
Year:98 to97
Model:tj
Engine:4.0
Transmission:auto out ax15 in
Transfer Case:np 231
Front Axle:d30
Rear Axle:d35
Axle Gear Ratio:3.07open
Suspension:skyjacker
Tires:courgia m/t
appox time 24 hrs of rewiring 98 harness into 97 cab and under hood pull and re-install motor trans t-case without help in yard with engine hoist on ply wood
97 motor ran like crap auto trans didn't run 33's well so i thought it was a good day to pull 4.0 and the ax15 off my broken 98 frame and use the harness from 98 to have the better style harness 97 and 98 were different in the fuse box an connections on fire wall under hood so it made sense to take all the wiring rather then putting older plugs and wires on the better motor and the 98 was cleaner when purchase and i kept it that way just got to find or build a new frame so i can hit the trails again without rippin off controll arms
None
Login Or Register To Post Comments
