Go Back JeepForum.com > Jeep Registry > TJ Wrangler > Nick's new TJ
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Nick's new TJ Jeep Registry
Previous Jeep TJ Wrangler Next Jeep
Nick's new TJ
Email Bookmark Print
NickDangerTJ
Jeep Information
Year:2000
Model:TJ
Engine:4.0l I6
Transmission:NV3550
Transfer Case:NP231J
Front Axle:Dana 30
Rear Axle:Dana 44
Axle Gear Ratio:3.73 (stock)
Suspension:3.5" Rough Country (I think) w/ Rancho shocks
Tires:33x12.50x15 Goodyear DuraTracs
Wheels:15" Pro Comp Rock Crawler steelies
Armor:Sun Performance rocker guards
Recovery Gear:None
Accessories:K&N cold air intake, red top Optima
Future Modifications:Too much to list
Just bought my TJ last weekend. This is now the third Jeep I've owned (first Wrangler, other two were XJs). I'm definitely having fun with it, and already have a long list of mods I'd like to do in the future. First thing I'd like is to put some new tires/wheels. The 31's are brand new, but it would look a lot better with some 33's. I'm think Pro Comp black steel wheels with either BFG KM2s or Goodyear MT/Rs. Any opinions or suggestions would be much appreciated. Will 33's run pretty decent assuming this is all stock gearing?
Edit 10/11/11: New picture with 33" DuraTracs and Pro Comp steelies. Sweet!
None
Login Or Register To Post Comments
flying_bosun
View flying_bosun's Jeep
09-10-2011, 04:55 PM
Congrats on the new rig.
Without knowing what the gearing you have, no one will be able to advise on tire size. "Stock" varies from jeep to jeep, so you'll have to figure out what you have. There should be a tag or stamp on each of your diffs that says what they are and you may be able to figure it using the "stock spec" sticky at the top of TJ Tech
Steel wheels are not recommended as they are often not true/round and can cause/exacerbate death wobble. I'd stick with what you have or try to find some moabs on Craigslist.
LJDesertRat
View LJDesertRat's Jeep
09-10-2011, 05:59 PM
You want to be sure that the vehicle is lifted sufficiently and your backspacing will allow for 33's as well. Congrats and welcome to the real Jeep league.
NickDangerTJ
View NickDangerTJ's Jeep
09-10-2011, 08:43 PM
I'm pretty positive it's lifted enough for 33's. I was searching around on the shocks today, they're Rancho RS5256, which on the Rancho site from what I can gather goes with either the 2.5 or 3.5 inch lift kits, and mine looks closer to 3.5 then 2.5.
I'm not too worried about Steel wheels being imperfect compared to Alloys (although thanks for the advice). I never had any issues with them on my XJ. It would be nice to save on the weight I suppose, but Steel are so cheap. 3.75" backspacing should be more then enough on 33's, correct?
NickDangerTJ
09-10-2011, 08:46 PM
Also, looks like I should be running 3.73 gears according to the TJ Tech sticky.
CountryBoysZJ
View CountryBoysZJ's Jeep
09-14-2011, 12:27 AM
I'm runnin ProComp Rock Krawler "D" window steelies with 3.75 back spacing and it's a 15x10 rim. Definitely need more flare. But they're sweet and don't rub unless your flexin 'er out pretty good.
CountryBoysZJ
09-14-2011, 12:28 AM
Oh and 3.73s are a b*tch when it comes to hills and 33s. Lol. But i manage for now. 6th gear is worthless though.
