Go Back JeepForum.com > Jeep Registry > TJ Wrangler > Habu's Rattle Box
WIN a Rough Country Forged Track Bar - ExtremeTerrain!FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6
Habu's Rattle Box Jeep Registry
Previous Jeep TJ Wrangler Next Jeep
Habu's Rattle Box
Email Bookmark Print
zgravity
Peterborough
Jeep Information
Year:1999
Model:SE
Engine:2.5L
Transmission:AX-5
Transfer Case:NP 231
Front Axle:D-30
Rear Axle:D-35
Axle Gear Ratio:4:11
Suspension:Skyjacker 2.5 inch springs, JKS front and rear adjustable track bars, Bilsrein 5100 shocks, Skyjacker quick disconnect sway bars, Rock Krawler front and rear top adjustable control arms
Tires:BF Goodrich TA ko 30-9.5-15
Wheels:factory aluminum
Recovery Gear:6000 pound winch the usual recovery gear
Accessories:Cobra 75 WX st CB with 5 foot firestick Alpine radio with sub and amp
Future Modifications:BF Goodrich TA ko 32-11.5 15 tires and armor
Just got her back from the shop and a new engine as she runs much better, gets better mileage, and has more power as the compression is stronger. IT still goes up hill slow but if you have a running start she does go up faster but flies on the flats real good.
Doing some body work to eliminate rust spots before they turn into huge rot holes. Then to the paint booth for a fresh coat and one color not 2 toned in spots.
Will post all the pick of the build when it's finished by end of month. Going to eventually replace the 5 speed AX-5 with an aftermarket 5 speed. Going to rebuild the 2.5 that came out of Habu and stroke it.
None
Login Or Register To Post Comments
