MauiYJ Jeep Registry
Previous Jeep YJ Wrangler Next Jeep
MauiYJ
Email Bookmark Print
87mauiYJ
Kula
Jeep Information
Year:1987
Model:Wrangler YJ
Engine:AMC 258 4.2L I6
Transmission:BA-10
Transfer Case:NP231
I am pretty sure I need a new transmission, but I know the BA-10 is crap. How easy would it be to put in a different transmission? AX-15?
None
Login Or Register To Post Comments
JeepingJustin
View JeepingJustin's Jeep
04-19-2013, 05:11 PM
If you could find a junk yj with that trans you'd be set. You'll need flywheel, clutch, pressure plate. Then the slave cylinder, pedal. I dunno if you'd need a diffrent bell housing if its coming off a 4 banger? Should be an easy swap if you got all that. Check the tech pages for yj, I'm sure there is threads on how to. Good luck.
