LangmuirCrawler Jeep Registry
Previous Jeep YJ Wrangler Next Jeep
LangmuirCrawler
Email Bookmark Print
toader
Albuquerque
Jeep Information
Year:1988
Model:YJ Wrangler
Engine:4.2 L
Transmission:Manual 5 speed
Transfer Case:Stock
Front Axle:Dana 30
Rear Axle:Dana 44
Suspension:Stock Leaves
Tires:Big Foot 30x9.50R15
Wheels:Jeep Logo 15" Alloys
Armor:Homemade radiator skidplate (more for sticks than rocks)
Recovery Gear:100 ft of 5/8" Bull rope (14000 lb test)
Accessories:GM TBI Fuel Delivery W/Howell Controller
Future Modifications:All of the above!
I Jeep therefore I am.
None
Login Or Register To Post Comments
toader
View toader's Jeep
03-09-2016, 12:46 PM
I started with a 88 YJ with a very tired 258 that had the Howell system installed on it. Pulled that motor out put in a rebuilt 1972AMC360 from a wrecked javelin. Put the Howell on that, changed the injectors to the ones for the Chevy 350 and now I put in the Moates G2 adapter plus zif socket. Got a Burn2 and a handful of 27sf512 chips. Now I'm waiting for the ALDL Bluetooth from 1320 electronics. Once I take the plunge into adding ESC to the setup I will be getting close to the perfect tune. I know I'll never get there fully but its a hobby, right? right. I Jeep therefore I am. This is the long story made short up to now. Following this post I intend to go back to the beginning and add the gory details.
toader
View toader's Jeep
03-09-2016, 04:52 PM
In 2014 I bought the 88 from another engineer i worked with for $1000.00 ! Wow ! He was tired of the "Just Empty Every Pocket" routine. I don't know how many times he told me that joke over the next year. He would ask me weekly what i had to fix on it and then say IT. (See above) I was not deterred. Not even a little. I had always wanted a Jeep. It had a worn out 258 that the mechanics had convinced him to put Howell on. Worse it had the Peugot BA.10.5 tranny. Oh well, it was a start.
Attachment 2741017
toader
View toader's Jeep
03-09-2016, 05:08 PM
I ran it for a year while i went through the learning curve. Then after two camping trips and oil fouled plugs forcing me of the road both times I decided to dive in and put an AMC 360 in and reconfigure the Howell for that. Here is the 86 waggy that donated the motor that i got most of my bolt on parts from. Manifolds, motor mounts, pan, rocker covers, dizzy, etc.
Attachment 2741025
below is the rebuilt core from the 1972 javelin wreck. I did not use the waggy core.
Attachment 2741033
Below is the new plant dropped into place. See the GM TBI where a crapburetor would s#it.
Attachment 2741041
it took a few weeks to get it running. Then over to the exhaust shop for a week and then it sat in my driveway for two months while I scrounged the parts to get the TBI system reconfigured for the 360.
toader
View toader's Jeep
03-09-2016, 05:52 PM
So after i got the system running just a little better than terrible it ate the distributor gears (both). And it had to sit in the weeds for a year while I put time/money into the house addition. Now that the house is done (yea right more like: half done!) I put new gears on the distributor and drive gear plus new timing chain and timing gears. I Made sure to put the oil slinger ring on the front of the crank shaft so it wouldn't chew up another distributor gear,oops!
toader
View toader's Jeep
03-09-2016, 05:56 PM
I put some old school big truck style mirrors on it. Hey, I can actually see out of these!
toader
View toader's Jeep
03-09-2016, 05:58 PM
toader
View toader's Jeep
03-09-2016, 05:59 PM
Burned a few versions of my bin so far. Tweaking start afr and idle, but I can't do any serious tuning until: 1) I get my ALDL Bluetooth transmiter and, 2) I take the plunge into spark control and modify my duraspark dizzy. hey self remember: its a war of attrition. I Jeep therefore I am.
toader
View toader's Jeep
02-28-2017, 12:04 PM
Dizzy modded to gm five pin module. No knock control, i think i need another degree of advance in the leadfoot region of the sparktable. It coughs once when i step on it too hard. Something going on with my alternator now, it dont charge good and volts are low at idle. No good for short hops.
Sent from my SM-G920T using Tapatalk
