kids first Jeep Registry
Previous Jeep YJ Wrangler Next Jeep
kids first
Email Bookmark Print
dkopp
san antonio
Jeep Information
Year:1995
Model:yj
Engine:2.5
Transmission:5 speed
Transfer Case:stock
Front Axle:30
Rear Axle:35
Axle Gear Ratio:4.11
Suspension:4 inch RC
Tires:33\15
Wheels:DC
Armor:rock front rear and side
Recovery Gear:12000 LB
Accessories:all
Future Modifications:all
I am finishing my sons first jeep 1995 Yj with stock 4 cylinder I have done a full restoration installed a lift 4 inch 33 inch tires new wheels.the jeep spent its life in Utah lots of rust. I installed new brake lines master cylinder new valve front calipers rear drums new seals extended brake lines the brakes were working great before I started I have been the only owner. The problem I am having is I can not get a firm brake pedal it will pump up but only the rear will grab I have ran two bottles of brake fluid thru it and can not get the brakes to work when I push the pedal it gos to the floor and the brake light comes on The dash cluster
What could it be it seems there is no air I find no leaks all parts car new except the booster. Hit a wall what do you think this is my first post as I am new to the forum I have owned jeep for 40 years and never had this happen.
Look forward to what ever help you can offer.
None
Login Or Register To Post Comments
Batty505a
View Batty505a's Jeep
05-06-2013, 03:11 PM
Master cylinder?
1987_yj
View 1987_yj's Jeep
05-07-2013, 08:29 AM
Not to insult your intelligence. But did you bench bleed the Master Cylinder before installing it?
