Go Back JeepForum.com > Jeep Registry > YJ Wrangler > Idles rough and then dies after check engine light
Yukon Ultimate 35 axle kit for c/clip axles with Yukon ZipSome Free shipping Coupon codesSPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!
Idles rough and then dies after check engine light Jeep Registry
Previous Jeep YJ Wrangler Next Jeep
Email Bookmark Print
ReeFer_YJ
Council bluffs
Jeep Information
Was driving to work and started running rough almost like a misfire and way underpowered. Got it home and so far I have replaced (in order) the cap,rotor, plugs,wires,CPS,o2 sensor, cut off cat, TPS,MAP sensor, fuel filter, intake exhaust gasket, tested resistance on injectors, timing chain sprockets chain and tensioner, oil pan gasket, distributor and checked ground for harness. I'm out of ideas Any suggestions
None
