Here's my 95 yj Jeep Registry
Previous Jeep YJ Wrangler Next Jeep
Here's my 95 yj
Email Bookmark Print
randall979
College Station
Jeep Information
Starting from the rear and within the last couple months, I've replaced the following: rear passenger wheel cylinder, fuel filter, muffler, cat, o2 sensor, manifold and gasket, valve cover gasket (the expensive blue one), rear temp sender unit, tps, iac, air filter, pcv, ccv, map sensor, dist, wires, coil, battery, and the jack under the hood. I went and had all the fluids serviced. I'm almost ready for a little suspension lift.
None
