Notices
Frankenstein CJ8 Jeep Registry
Previous Jeep CJ-8 Scrambler Next Jeep
Frankenstein CJ8
Email Bookmark Print
Knucklehead
Woodbridge
Jeep Information
Year:2013
Model:CJ8 Scrambler
Engine:304
Transmission:T150
Transfer Case:D20
Front Axle:D30 w/Lockright
Rear Axle:AMC 20 w/rebuilt Tracloc
Axle Gear Ratio:3.55
Suspension:Reverse shackle YJ RE 4.5" front, Iron Rock XJ 6.5" rear
Tires:Treadwright 315/75-16 Guard Dogs
Wheels:Summit 16x10 aluminum
Armor:Home-built tube fenders, 2x4" shorty front bumper
Recovery Gear:Shovel and a strap
Future Modifications:T-18, TeraLow D20 3.15 gears, winch
Built from two donor CJs - a '76 CJ5 and '78 CJ7 hence the 304, T150 and D20 drivetrain. TDK frame ordered to used reverse shackle YJ front springs and XJ rear springs. Despite the tall stance, it has a great ride. Willys-Overland tub. List of parts and mods:
-TDK frame
-Rubicon Express YJ 4.5" front springs
-Iron Rock Offroad XJ 5.5" rear springs with 1" add-a-leaves
-Rubicon Express boomerang shackles front and rear, greasable bolts
-Willy-Overland steel tub
-Home fab'd tube fenders (1 3/4" tube)
-Rebuilt 304
--9.0 compression
--Ported heads with 1.94 and 1.5" Chevy valves
--Howards 214*/220* duration, .527/.540 lift cam
--Stock 2bbl intake with rebuilt MC 2100 (from a late 60s Mustang)
--Hedman Elite headers into single, full length 3" exhaust
--HEI distributor
-Complete rebuilt drivetrain - T150/D20/D30/AMC20
--Front disk brake conversion
--Lockright front and Tracloc rear diffs
--1-piece AMC20 axleshafts
-Power steering conversion
-Power brake conversion
-'78 CJ7 front sway bar
-Flaming River tilt steering column and steering shaft
-Grant steering wheel
-Summit heater and "custom" heater/defroster system
-Stock replacement speedo and VDO gauges
-Corbeau seats on modified CJ7 seat bases (to correct seat angle and height)
-Modified CJ5 rollbar to fit CJ8 mounting
-Sprayed in Duplicolor Bed Armor bedliner
-35 gallon Aerotank gas tank
-Stainless steel brake lines with braided brake hoses
-Currently riding on a set of Treadwright 315/75-16 Guard Dog tires mounted on Summit 16x10 aluminum wheels.
-Bestop Supertop and bikini tops, YJ half doors
-JVC CD radio and Kicker speakers
Every part, nut and bolt on this beast was rebuilt, modified, turned, or tightened by me during the build over the summer of 2013. Built it for my youngest daughter who is now driving the Scrambler every day to school and around town (had to learn to drive a manual trans first). Fresh engine runs great, it has a great ride and steering, and stops straight. Suspension works fantastic on and off road and is the best riding leaf sprung CJ I've ever been in. Not done yet, picked up both a Ford T18 and T19 to possibly swap in and looking for the best value on a TeraFlex D20 low gearset to swap in someday. This one will be a family heirloom, passed down through the generations.
http://www.jeep-cj.com/forums/f98/cj...d-parts-18789/
None
Login Or Register To Post Comments
