I have a 77 cj7 360 AMC 1406 edelbrock 4 barrel with edelbrock intake. Here's the problem: cold starts will start right up I'll take it for a ride runs fine after it warms up and sits for at least 5 or 10 min it will not start I have to get on it cranking over and over. So this is what I've done put an electric fuel pump edelbrock. Put a 1 inch spacer for vapor lock. Is it a float problem? Electric choke problem? It's not running hot have a low temp for radiator plus it's 34 degrees
out side. As long as I don't turn it off it runs like a champ. If I turn it off then crank it over again really quick it will turn over no problems. Just when it sits for a while after its hot. ANY SUGGESTIONS WELCOMED
