Notices
Jeremie's cj7 Jeep Registry
Previous Jeep CJ-7 Next Jeep
Jeremie's cj7
Email Bookmark Print
Jeremieb
Oneida
Jeep Information
Year:1978
Model:Cj7
Engine:360
Transmission:T400
Transfer Case:Quadratrac
Front Axle:Dana 30
Rear Axle:AMC 20
Axle Gear Ratio:456
Suspension:SOA
Tires:33"x12.50"
Wheels:15x10
Alright here's my problem. I bought the jeep with SOA but had a problem with an axle and found both front and rear to replace them with lockers, 456 gears, shackles, and lift springs. When I installed them it lifted it quit abit. As it sits there is about 12" of clearance from tire to fender. It has a 4" drop pitman arm however the bump steer is really bad! In this situation was is my best bet? Return to SUA(drive have slip yokes and spring mounts are still there) or use something like a z-link to fix drag link offset?
None
Login Or Register To Post Comments
