I tried....My CJ build Jeep Registry
Previous Jeep CJ-7 Next Jeep
Email Bookmark Print
Captainak
Hemitage
Jeep Information
Year:1982
Model:CJ7
Engine:AMC 401
Transmission:T 18
Transfer Case:DANA 20
Front Axle:DANA 30
Rear Axle:MODEL 20
Axle Gear Ratio:4:11
Suspension:SKYJACKER 2.8"
Tires:Interco TrXus M/T 33x12.50 tires
Wheels:Pro Comp USA Series 98 Steel Wheels, 15"
Armor:WARRIOR PRODUCTS, OLYMPIC, HANSON, WARN
Recovery Gear:WARN POWER-PLANT 9600LB WITH COMPRESSOR
Accessories:TO MANY
Future Modifications:CJ TO YJ CONVERSION
1982 JEEP CJ-7
Wide Track
http://jeepspace.jeepforum.com/Captainak
ENGINE
AMC 401 Performance Pump Gas built by CMEngines of SC, 10:1 Compression & Oiling Modifications
- 427 Max HP @ 5300 RPM's
- 498 Max Torque Ft. Lbs. @ 3900 RPM's
CN: 3198951
CLUTCH
Centerforce, 10" Dual Friction Clutch Pressure Plate with Disc & Billet Steel Flywheel
PN's: DF180675 & 700730
Extreme Custom Fabrication, Hydraulic Clutch Conversion
TRANSMISSION
Borg-Warner T-18, Jeep, 1979, Reverse over then down and "Granny" non-synchro low, 6.32:1 first gear, rebuilt
TRANSFER CASE
Dana 20 Transfer Case, 1973, C104 Jeepster Commando, with twin stick for FWD only drivability, rebuilt
DRIVE LINES
Stock Drive lines that were possibly extended for lift by prior owner, UNKNOWN
FRONT AXLE
Dana Model 30 Front Axle, Eaton Performance Detroit Trutrac Limited Slip Differential,
For 27 Spline with 3.73 and Numerically Higher Gear Ratio
PN: 912A314
REAR AXLE
AMC Model 20 Rear Axle with Superior Single Axle conversion & Eaton Performance Detroit Locker, For 29 Spline with 3.08 and Numerically Higher Gear Ratio
PN: 187SL-47A
WHEELS
TIRES
LIFT
2.5" Skyjacker, Spring Under Axle
UNKNOWN
2.5" body lift
Jeep
1979 /1981 / 1982 Jeep CJ7 "CUSTOM" Vehicles
1982 JEEP CJ-7 VIN: 1JCCM87E5CT025527
5465280024269271
4-14-135
AMC 401 is from a 1971-1978 Jeep (1977 J 20)
Casting Number: 3198951
Aluminum Tub (Armor lined interior)
Fiberglass lift off front end
Bestop Strapless Bikini Black Denim Bestop Supertop with Tinted Windows
Black Denim Bestop Half Doors Black Denim Formula GT Black Grip with Satin Black Spoke 12" Steering Wheel
Smittybilt G.E.A.R. Seat Covers Front and Rear Black
Rugged Ridge Black Denim Front Seats
Rugged Ridge Black Denim Fold & Tumble Rear Seat
Rugged Ridge Black Denim II Locking Center Console
Rugged Ridge Black Denim Roll Bar Cover
Rugged Ridge Black CJ7 Floor Mats
Bushwacker 6" Cut Out Fender Flares
Warrior Products Black Diamond Corner Plates (Powder Coated)
Warrior Products Black Diamond Side Plates w/ Under Lip (Powder Coated)
Warrior Products Black Diamond Tail Gate Plate (Powder Coated)
Warrior Products Black Diamond Back Plate (Powder Coated)
Warrior Products Black Diamond Entry Guard Plate (Powder Coated)
Custom Built Black Diamond Plate Front Grille Cover (Powder Coated)
Kentrol Hood Kit Black (Powder Coated)
Gen-Right Off Road 3pc "short" Hood Louver Set
Run Cool Jeep Side Hood Louver set (18")
Kentrol Windshield & Door Hinge Set Black (Powder Coated)
Kentrol Tailgait Hinge Set Black (Powder Coated)
Kentrol Glove Box Door Black (Powder Coated)
Hanson rear bumper (Armor lined)
Warn front bumper (Armor lined)
Warn Grille Guard (Armor lined) Warn Winch Plate (Armor lined)
Olympic Extreme Reversa-Bars (Armor lined)
Custom Self Built 3/8" Steel Shackles Blue (Powder Coated)
Daystar Greasable Shackle Bushing Kit Black
Quick Fuel Technology
Street Carburetor 780 CFM VS
Part#: SS-780-VS
Edlebrock Performer Intake (Powder Coated)
Aluminum Valve Covers (Powder Coated)
MSD Blaster 2 Coil Hi-Performance
MSD Pro-Billet Ready to Run Distributor
MSD Ignition Control
Moroso Blue Max Race 8mm Wire Set
Daystar Polyurethane Motor Mount Black
Professional Products 91102 AMC Harmonic Dampener
Bulltear AMC Serpentine Aluminum Pulley Conversion Kit
Warn PowerPlant HP 9500lb Winch & Air Compressor w/ 2.5 Gallon Tank
Warn Neoprene Winch Cover
Bubba Rope Towing Rope 30' Blue 28,600 lbs.
Oil Pan w/ Custom Built 3/8 Aluminum Skid Plate (Hurculined)
Headman Hedders Wrapped and Coated with Design Engineering Black
DRIVE TRAIN
Borg Warner T-18, 4 speed with Granny Low 1st, modified vent tube relocation to engine compartment, rebuilt
Centerforce 700730 BILLET STEEL FLYWHEEL
Centerforce DF180675 Dual Friction Clutch Pressure Plate and Disc
Dana 20 with Twin stick conversion with front wheel drive only ability, modified vent tube relocation to engine compartment,rebuilt
Energy Suspension Transmission & Torque arm mounts
Crossmember custom cut and filled, powder coated & Hurculined
Dana Model 30 Front Axle (Dana 60, GM M1008 CUCV 14 bolt PENDING)
AMC Model 20 Rear Axle with Single Axle conversion (Dana 60, GM M1008 CUCV 14 bolt Detroit Locker PENDING)
For 29 Spline
REAR
AMC Model 20 Axle with 3.08 and Numerically Higher Gear Ratio 187SL-47A
For 27 Spline Dana 30 Axle with 3.73 and Numerically Higher Gear Ratio 912A314 FRONT
4:11 gears
Blu Torch Fabrication HD Differential Cover & Truss Support (Black Powder Coated)
Pro Comp USA Series 98 Steel Wheels X 5 (Powder Coated)
Weld on Beadlocks (pending)
Gorilla Wheel Lock Set Black (Powder Coated)
Smittybilt Tire Deflators
Aluminum 2.5" Wheel Spacers Black (Powder Coated)
Heavy Duty Steering Shaft Black (Powder Coated)
KC Lites, Rock Guards & Wind Shield Mounts x 3 (8", 6", 4.5")
turnsignal and running light LED conversion
Halogen Conversion Headlamp
Jegs 12 Circuit Universal Wire Harness
Dual Battery Tray
Blue Sea Marine heavy duty dual battery shut off
Optima Yellow Top Battery
Optima Red Top Battery
Dakota Digital Series III Blue LED Gauge Panel CJ Conversion
Pioneer KVT-596 DVD / Navigation / Blu Tooth stereo with reverse camera
Pyle Marine PLMRA 620 6 CH Amp / 2000 watt RMS
Polk Audio 5.5" 125 RMS front
Polk Audio 6x9" 100 RMS rear
Supreme Sound Wedges 6x9" Box
Polk Audio 2- 8" 250 RMS sub woofers
None
Login Or Register To Post Comments
Captainak
View Captainak's Jeep
04-05-2011, 02:12 PM
Progress is made
Sent from the iPhone, "82" CJ7 Built Not Bought, Captain, USA (RET)
Captainak
04-15-2012, 09:44 AM
Ok update ...... This saga continues ...... Bought my CJ off eBay in JAN of 2010 and I have ***MABEY*** 3 months drive time on it ........ Lol
Fiberglass Tilt Front End
Edlebrock Thunder Series Carberator
rebuilt
Extreme Custom Fabrication, CJ7 Hydraulic Clutch Conversion Kit
Dana 20 with Twin stick conversion rebuilt
For 29 Spline AMC Model 20 Axle with 3.08 and Numerically Higher Gear Ratio 187SL-47A
REAR
4:11 gears
Dual Battery Tray
marksud
View marksud's Jeep
06-24-2012, 01:30 PM
Where did you get that gauge?
Captainak
06-24-2012, 05:58 PM
http://www.dakotadigital.com/index.c...&article_id=16
http://www.dakotadigital.com/index.c...cat/cat410.htm
