CJ-7 TPI Vette Jeep Registry
Previous Jeep CJ-7 Next Jeep
CJ-7 TPI Vette
Email Bookmark Print
TPI-CJ7
Carbondale
Jeep Information
Year:1978
Model:CJ7
Engine:L98 '90 TPI vette 350
Transmission:T-18
Transfer Case:Dana 300
Front Axle:Dana 44 w/ ARB
Rear Axle:Dana 44 w/ ARB
Axle Gear Ratio:3.73
Suspension:2.5" Rancho
Tires:33-9.50-15 BFG Mudders
Wheels:15x8 Modular
Armor:Diamond rear quarters and rockers
Recovery Gear:Ramsey 8000 w/ accessories
Accessories:Powder coated headers & custom exhaust system w/ Flowmaster mufflers C.O.D.E. custom motor mounts Original jeep T-18 (low-low range) transmission Dana 300 (scout) transfer case Custom boxed and reinforced frame ARB front and rear air lockers 3.73 gears Custom front & rear Dana 44 axles (C.O.Design) & front assembly truss reinforcing Summers Brothers one piece rear axles Custom front rotors/hubs (Ford - re-drilled to Jeep pattern) Custom (C.O. Design) front Trac-bar Aluminum (Griffin) radiator & elec. fans (could upgrade) Centerforce clutch pac Lakewood scatershield bell housing Custom dual battery holder Arrow high capacity fuel tank Rancho 2-1/2" suspension Front suspension shackle swap Quick disconnect front sway bar 33/9.50-15 BFG Mud Terrains (Moab compound) AJ Deluxe one piece fiberglass & Kevlar front clip Upgraded power brakes and power steering M.O.R.E. Steering box torsion bar Custom roll cage with four points directly to frame with urethane bushings Beard Seating and 5-point safety harness mounted to Roll cage - not jeep body tub Custom console with ARB controls, lighting controls, CB, 6 Disc changer Custom bikini top with custom attachable frameless fastback top and soft doors, custom carpet kit '85 CJ 7 hard top and doors (improved latching system) Custom front and rear bumpers with integral tire/gas can rack Ramsey 8,000 lb. winch Off Road lighting Alpine audio with two external amps and rear subs Custom covered rear cargo cover Grant Steering wheel on tilt column
Future Modifications:new elec. fan (more cfm)
I am trying to sell my CJ of 25 years... a sad decision but kids and family have changed our priorities... for the better.
None
Login Or Register To Post Comments
Drtnap2012
View Drtnap2012's Jeep
05-17-2013, 01:03 AM
Sorry to hear about the sell, maybe just garage it for another 25 years,kids will luv it!
