"Casper" Jeep Registry
Previous Jeep CJ-7 Next Jeep
"Casper"
Email Bookmark Print
dtperk
columbia station
Jeep Information
Year:1982
Model:CJ-7
Engine:258 / 4.2 (Bored .30 Over)
Transmission:T-4 (Full Rebuild)
Transfer Case:Dana 300 (Full rebuild)
Front Axle:Dana 30
Rear Axle:AMC 20
Axle Gear Ratio:4.10 (originally 2.73)
Suspension:2.5" Skyjacker / 1" Shackle / 1" Body
Tires:33 x 12.5 BFG MTs
Wheels:White Steel Wagons
Armor:Front Push / Side Nerfs
Recovery Gear:Frame mount Tow Hooks - All 4 corners
Accessories:Bestop Seats / Cobra CB / Tuffy security center con.
Future Modifications:None - Rest In Peace
Year long, frame up restore.
4WD Glass Tub / Fenders - Original Steel Hood / Windshield frame.
SS 4WDH Dash / Knobs / Oh Sh*T grab bar - All stainless bolts/hardware/hinges
SS lines - Brake and Fuel
GM HEI Setup
Weber 32/36 - K&N Filter
Borla SS Header
York on-board Air setup / 2.5 gal reserve tank / Quick Disconnects - Frt/Rr (air up / air down!)
AMC 20 - Welded tubes, 4.10s installed, ARB Air spool, Moser 1pc Axles
Dana 30 - Complete rebuild - Seals, ball joints, u-joints, Warn L/O Hubs, Lock-Right locker
GM Blower motor upgrade.
Painless Full harness / Fuse block - Additional Painless AUX fuse Block installed
All yokes drilled for straps / nuts
AGR(?) Steering box / pump
Every seal, bolt, nut, strap, hinge, cable, line - you name it - was replaced
Man, I miss that CJ!
None
Login Or Register To Post Comments
