Go Back JeepForum.com > Jeep Registry > CJ-7 > Big Yellow
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Big Yellow Jeep Registry
Previous Jeep CJ-7 Next Jeep
Big Yellow
Email Bookmark Print
Jclilk
Pembroke Pines
Jeep Information
Year:1986
Model:CJ7
Engine:4.2 6 cylinder
Transmission:T5
Front Axle:Dana30
Rear Axle:Dana 44
Tires:33 x 12.4
My CJ7 is super STIFF!!! omfg its unbelievable, you can't even shake it when its in a complete stop and going thru speed bumps is a mission .... Anyways, i was looking into buying Bilstein 5100 series shocks. would that be a good choice for my CJ7? and would buying shacle reversal help? and where could i get a nice 1 and cheap. please help!!!! and thank you!
None
Login Or Register To Post Comments
row684
View row684's Jeep
12-21-2012, 11:18 AM
Post this up in the CJ forum you will get a response.
diddy2003
View diddy2003's Jeep
12-21-2012, 11:23 AM
I would think that your springs play the biggest role in how stiff the jeep is. If you want to keep it that height some OME YJ sprigs would make a huge difference. I would not do a shackle reversal. Not a fan.
GTNMUDY
View GTNMUDY's Jeep
01-26-2013, 09:02 AM
Let some air out of your tires.
I run 33 x 12.5 on my 84 CJ7. I adjust the air pressure by making sure all of the thread in touching the ground. I run about 26 lbs in the tires.
This gives me a full tire contact and a softer ride.
Another area to look at is the springs. If they have been worked on and the bands are too tight they will not let the springs move when you hit a bump.
I removed and dis assembled mine, cleaned them up and put a coat of grease between the springs. This helped with the stiffness.
Nice looking CJ
79cj7amc304auto
View 79cj7amc304auto's Jeep
01-30-2013, 11:07 PM
Nice looking CJ
Nice suggestion... I like. Like the post originator i tooI was thinking the same thing about the shocks. Mine are shot... do u recommend the bilstein 5100's or something else?
ivrider
View ivrider's Jeep
02-24-2013, 10:14 AM
What size tires are those? Do you have a lift?
CJDees7
View CJDees7's Jeep
03-14-2013, 04:22 AM
The one in the photo looks to be sporting a set of 33's with a 2-2.5" suspension lift.
