Go Back JeepForum.com > Jeep Registry > CJ-6 > Cjsixer
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Cjsixer Jeep Registry
Previous Jeep CJ-6 Next Jeep
Cjsixer
Email Bookmark Print
CJSIXER
Salem
Jeep Information
Year:1970
Model:CJ-6
Engine:305ci TPI Chevy V8
Transmission:NV4500
Transfer Case:Dana 18
Front Axle:Dana 30
Rear Axle:Dana 44
Axle Gear Ratio:4:88
Suspension:Skyjacker 4 inch lift
Tires:35x12.50r15 Super Swamper SSRs
Wheels:Procomp Soft 8
Armor:Off Your Rocker corners and rockers
Recovery Gear:Warn 9.5XP
Accessories:See Description
Future Modifications:Another axle swap along with an automatic and Dana 300
The build up of my CJ was well documented on JeepsUnlimited.com as I was the administrator of that website when I was building the Heep. My CJ came out of Pennsylvania and it was originally equipped with a PTO driven trencher and used by a power company to lay cable. The Jeep had signs of originally being equipped with a half cab soft top. When I got the Jeep the front axle had been stripped of its gears and shafts and the Dauntless V6 was tired.
I tore the Jeep apart in 1999 and put it back on the road about 6 years later. The build list changed several times and now after having it back on the road for about 5 years I am considering another major drivetrain revsion that would replace the front and rear axle with a Dana 44 and Ford 9 inch respectively and replace the transmission and transfercase with a TH350 and a Dana 300.
Here are a list of modifications as it currently sits.
Frame and Body:
-Boxed the frame and reworked the front and rear cross members
-Replaced a considerable amount of the floor and reworked the firewall to fit the Chevy V8
-Cut the rear fender wells for TJ flares.
-Sprayed the Jeep with Flat Desert Tan paint and Rhino Lined the interior and under side.
-Installed Off Your Rocker tall corners and rocker guards
-Built a full cage with a sub frame to mount the seats to.
-Installed Mastercraft Rubicon front buckets and a rear bench
Drivetrain:
-Swapped in a Dana 30 front from a 1975 CJ with 1978 style disc brakes.
-Used the factory off set 30 spline Dana 44 rear axle
-Put a Detroit Soflocker in the rear and 4:88s in both axles.
-Installed a Tuned Port Injection 305ci Chevy V8 from a 1992 Camero
-Installed an NV4500
-Rebuilt the factory Model 18 transfercase with Teralow 3.15 to 1 gears, a Novak Intermediate shaft and a transfercase girdle from Tri County Gear
-Built a Saginaw Power steering conversion using a Mullins Saginaw 500 power steering box, an 87 Comanchee pick up tilt column, a Borgeson steering shaft and a Big Daddy Offroad HD Tie Rod set up which was flipped on top of the knuckles.
Suspension:
-Skyjacker 4 inch suspension lift with 1 inch shackles and a 1 inch body lift
-UBolt skid plates from JKS
-Teraflex YJ front shocks using Ford F250 shock towers, rear Skyjacker shocks.
Other mods:
-Kilby On Board Air
-Warn 9.5 XP Winch with Viking rope to replace the cable
-BeCool branded Spal fan
-Garvin Industries YJ Wrangler rear tire carrier bumper combo modified to fit the CJ
-Painless Wiring through out
-Newer CJ Dash with Autometer Gauges
None
Login Or Register To Post Comments
