Pink Bull Jeep Registry
Previous Jeep CJ-5 Next Jeep
Pink Bull
Email Bookmark Print
Jeep Information
Engine:V8 304
Transfer Case:Dana 20
Front Axle:Dana 30
Rear Axle:Dana 44
Axle Gear Ratio:3.73
It's not pink now, but it will be. I bought this Jeep on Craig's List for $600 for my wife. The plan is to paint it pink with gray and black trim; no chrome, no stainless, all pink, gray, and black.
It appears to have had many owners and many mods, some good, some not so good. The goal is to return most things to stock or something close. However, it has a very heavy duty custom front brush guard. Welded to the center is a bull silhouette. The brush guard will be grey and the bull pink. On the hood, where it previously said RENEGADE (though it doesn't appear to be a Renegade), it will say PINK BULL.
To achieve this, I have already stripped it down to the frame. In a few weeks, I expect to be ready to start assembly.
Login Or Register To Post Comments
View hedgero's Jeep
05-27-2012, 10:04 PM
Project Update
This post will bring the project up to date. I intend to use this as a method to keep track of what has been done and when. Hopefully, when it comes time for re-assembly, it will also act as a refresher to make sure I don't miss anything.
This is a weekend project, so you'll notice that's when the work happens.
Weekend of April 14th, 2012
Removed hood, windshield, dash, battery, starter, and all wiring under hood and dash.
Weekend of April 21st
Removed steering column, pedals, roll bar, tub.
Weekend of April 28th
Removed gas tank, brake lines, brake master cylinder, fuel lines, and all remaining wiring.
Weekend of May 5th
Removed hoses, radiator and grill, fan, alternator, exhaust pipes, exhaust manifold.
Weekend of May 12th
Removed clutch linkage, drive shafts, and carbuator.
Weekend of May 19th
Removed transfer case, transmission, bell housing.
Took 4 day weekend for Memorial Day - May 25th
Removed clutch, flywheel, front pulley, vibration damper, oil pan, intake manifold, valve covers, rocker arms (etc.), and heads. Everything in the engine appears to be in excellent condition so far. It also appears that the engine has been disassembled before.
Finally lifted engine from frame. I was not looking forward to this, as I do not have a hoist and I'm working alone. But I had an idea and it worked. I positioned a ladder right next to the Jeep. I then strapped a 2X4 to the engine. I placed on end of the 2X4 on a rung on the ladder and hoisted the engine off the frame by lifting the other end. I rotated the 2X4 around until I could rest my end on the work bench. I then lifted the other end to place it one rung higher on the ladder. This gave me enough height to get it on the work bench. I'm not sure if this will work to get it back on.
Removed motor mounts from the frame and steering gear box. Then I finally got the front bumper/brush guard off. It appears to have been fabricated by a previous owner and it was both bolted and welded. And parts were welded over the top of bolts that needed to be removed to get it out.
And since it's now Sunday evening, this post is completely up to date.
View squirrelly1's Jeep
07-18-2012, 09:25 PM
Looks like a good beginning. What year is it? I joined the site a couple a years ago and I'm just starting to use it. Need to figure out a bunch of things. Lol
View hedgero's Jeep
07-28-2012, 08:18 PM
It's a 1974.
Weather and work have slowed me down. Since my last post, I've removed the frame from the axles. Getting the leaf springs disconnected from the frame was a chore. Had to cut one of them (bolt, that is).
I stripped everything off the frame (misc. bolts and brackets) and began cleaning it up. But I burned up my angle grinder wire brushing it, so now I take another break.
Will post more photos soon.
View hedgero's Jeep
07-28-2012, 08:44 PM
Picture From Earlier
These are pictures from April. They are intended to help me remember what goes where when I start putting things back together.
View hedgero's Jeep
07-28-2012, 08:52 PM
Pictures from May
I was trying to make sure I had the model information right.
Dana 30 front.
Dana 44 rear with 3.73 ratio.
Dana 20 transfer case.
Borg Warner T15 transmission.
View hedgero's Jeep
07-28-2012, 09:02 PM
Frame Off!!!
The frame is finally off. Now the real fun begins.
View hedgero's Jeep
08-05-2012, 03:25 PM
Moved to Builds Forum
I think this will be better in the Builds forum, so I will continue this thread there:
View imnanas's Jeep
03-12-2013, 07:50 PM
I have a pink jeep, though no bull!
