Enuf 4 Jeep Registry
Previous Jeep CJ-5 Next Jeep
Enuf 4
Email Bookmark Print
ENUF
LAKE FOREST
Jeep Information
Year:1980
Model:CJ 5
Engine:258
Transmission:4 SPEED
Transfer Case:300
Front Axle:DAN A 30
Rear Axle:AMC 20
Suspension:SOA FROM ROCKY-ROAD WITH STOCK YJ SPRINGS.
Tires:35X13.5X15 TOYA MT
Wheels:AMERICAN RACING 15X10
Recovery Gear:MILE MARKER, HI-LIFT
Future Modifications:CHEVY 350 ENGINE
I just add a soa lift with yj stock springs and changed the rear shackle hangers. My problem is the bolts that came with the new hanger that go through the shackle to the hanger ate 9/16 and the shackle holes are 1/2.
The second concern is i ordered a bushing kit for the springs and did not get any metal sleeves or inserts for the bushings and i think i need those because the id on the bushings is like 5/8 and i feel with the metal sleeves that go in the bushings will make the id size 9/16 but here again i run into the shackle is drilled out to a 1/2. Has anyone run into this concern and if so what was the fix?
None
Login Or Register To Post Comments
