CJ restoration Jeep Registry
Previous Jeep CJ-5 Next Jeep
CJ restoration
Email Bookmark Print
Armyrules2
Jeep Information
Year:1977
Model:CJ-5
Engine:AMC 360
Transmission:T-18
Transfer Case:Dana 300
Front Axle:-
Rear Axle:-
Axle Gear Ratio:-
Suspension:Leaf springs with skyjacker shocks
Tires:All terrain Radial
Wheels:-
Armor:Diamond plate corner guards
Recovery Gear:-
Accessories:-
Future Modifications:-
I plan on restoring this jeep and building it up nice. I want to put a 4 in susspension lift on instead of the body lift it has now. Any tips anyone can offer would be greatly appreciated.
None
Login Or Register To Post Comments
rootbeerfreak21
View rootbeerfreak21's Jeep
12-17-2013, 02:56 PM
All I would say is you need to take your time. I just got done building one.
Armyrules2
View Armyrules2's Jeep
12-30-2013, 08:09 PM
Looks great! Thanks for the tip.
Armyrules2
12-30-2013, 08:52 PM
Mine has rust issues in the floor and floor supports. Did you have to do much with rust when you did your jeep.
rootbeerfreak21
12-31-2013, 03:21 AM
A lot redid all the floor pans and all the area under the doors but other than that not much just a little in the back quarters. The old full roll cage rusted the floor pans
Armyrules2
01-01-2014, 11:45 AM
Yeah mine sounds the same. Old roll cage rotted out at the base and the floor pans. The rear quarters look to be in food shape surprisingly. Did you just patch the pans or did you replace the whole pan.
rootbeerfreak21
01-01-2014, 12:34 PM
What I did was took patch pans that we bought from quadratec and the cut out the same piece from the matching patch pan
rootbeerfreak21
01-01-2014, 12:38 PM
if there was a small spot we used the remaining pieces of the patch pan
