widow regulater - JeepForum.com
post #1 of 5 Old 03-31-2014, 10:55 AM Thread Starter
pentastarguy
2015 JK Wrangler
widow regulater
is there an after market motor for power windows that i want to use or go to jeep? tks all
pentastarguy is offline
post #2 of 5 Old 03-31-2014, 08:23 PM Thread Starter
pentastarguy
2015 JK Wrangler
really, you all get these from the dealer???????????
post #3 of 5 Old 03-31-2014, 09:50 PM
profdlp
2007 KJ Liberty
I am not an expert, but this is a common problem. The answer I see most often is to go with Steiger:
http://www.steigerperformance.com/libertywizard/
profdlp is offline
post #4 of 5 Old 04-01-2014, 07:00 AM Thread Starter
pentastarguy
2015 JK Wrangler
tks for that.
post #5 of 5 Old 04-02-2014, 04:27 AM
AVR2
The Steiger kit is specifically for fixing the plastic bracket. If your problem is actually the window motor rather than the bracket, you'll have to replace the entire regulator assembly - nobody sells just the motor AFAIK.
The only regulator replacement options I know of are OEM or Dorman. The Dorman unit is advertised as an "improved design" over OEM, but I don't think it's been around long enough yet to know if the bracket lasts longer than the OEM one (which *will* break again).
AVR2 is offline
