Wicked noise - engine area. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > Wicked noise - engine area.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineG2 Disc Brake Conversion Kit for Jeep Wrangler YJ TJ LJ ChRough Country Jeep Suspension Deals at Rockridge 4WD!
Unread 09-13-2014, 05:30 PM   #1
notsoeloquent
Hello fellows,
Our beloved 2002 Libby has developed this tapping/clanking sound out of the blue on a cold start last morning. It is scary to think this could be a spun bearing or some rod issue. I have also heard suggestions ranging from fallen rocker arm to a cracked flexplate.
Is there any reasonably reliable way to diagnose? Should I just open my valve covers and look in there? If not I'll just deliver it to a decent mechanic on Monday.
Thank you.
notsoeloquent is offline   Reply With Quote
Unread 09-13-2014, 06:47 PM   #2
1coopgt
2005 KJ Liberty
Is there any oil in it ? Damn .
1coopgt is offline   Reply With Quote
Unread 09-13-2014, 07:01 PM   #3
02blue
2002 KJ Liberty
I'd definitely pull the valve covers and have a look. Does it stop when it warms up? If so it may just be a bad lash adjuster. If a Rocker dropped it would not stop when warm. I've got one bad lash adjuster that ticks loudly for about a minute SOMETIMES. I know what one it is but drives me nuts. Haven't had a chance to pull my VC.
"Hey, ya never know til you try." Kurt Russell-Big Trouble in Little China
02blue is offline   Reply With Quote
Unread 09-13-2014, 08:24 PM   #4
notsoeloquent
Yes, there's synthetic in it, done less than 2k miles ago. Dipstick seems fine. Is it possible that oil is not getting where it needs to because of some type of sludge?
I might try to open valve covers tomorrow if I have time, but could it be something as stupid as exhaust leak? It sounds like a damn tank now.
Oh yeah, it doesn't stop when warm, but it is possible that it gets quieter. It is also possible I'm just imagining things.
Unread 09-13-2014, 08:36 PM   #5
RockRollin
"Positive.....I think"
RockRollin's Avatar
1990 FSJ Wagoneer
Sounds like exhaust to me.
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
RockRollin is offline   Reply With Quote
Unread 09-13-2014, 08:46 PM   #6
02blue
2002 KJ Liberty
If you dropped a rocker you'd get a misfire code. Well, at least I did.
Unread 09-14-2014, 10:02 AM   #7
1coopgt
2005 KJ Liberty
I'd take one of the valve covers off and start it up to make sure there is oil flowing through the engine .
Unread 09-15-2014, 11:40 AM   #8
notsoeloquent
Broken connecting rod I'll be lucky if I get engine swapped for 2k, thats the quote so far. He said no signs of overheat - go figure. I'm really lucky with this jeep haha
Unread 09-15-2014, 04:08 PM   #9
TwoBobsKJ
2003 KJ Liberty
You can replace the engine with a newer 3.7 out of another Chrysler product if you do a couple of things to make the updated engine compatible with your 02's computer. Read thru this:
http://www.jeepkj.com/forum/f202/eng...verview-53270/
Bob
2003 Renegade, Black
- 3.7L, 42RLE, 4.10's, 4X Guard Trans skid, Factory Engine, T-case, Tank skids, Modded BoulderBars sliders, OME 927/948, Bilsteins, JBA A-Arms & 1/4" top plate, 1 extra rear iso/side, Moabs with Firestone Destination AT's 255/70-16
TwoBobsKJ is offline   Reply With Quote
Unread 09-15-2014, 04:32 PM   #10
olliehopnoodle
1982 FSJ Cherokee
They are not too bad to pull yourself. There is a write up on them in this forum.
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline   Reply With Quote
Unread 09-15-2014, 05:59 PM   #11
notsoeloquent
No guys, it is not doable without a garage and an array of tools and time. My guy will charge me 700$ for labor and that sounds very fair. With my experience and resources I couldn't tackle this period, but if I did it would take weeks. Otherwise I can have it by Sunday!
Money hurts but I've already given up on that amount
P.S.Any idea why the rod would fail like that? Engine sounded really clean before it happened - I've definitely taken care of it, no abuse either... Sick to my stomach having to pay for this
Unread 09-16-2014, 02:51 PM   #12
olliehopnoodle
1982 FSJ Cherokee
$700 for a swap is very fair.
You said some mechanic confirmed it was a 'broken rod'. How did they determine this?
Unread 09-17-2014, 04:57 PM   #13
notsoeloquent
I don't know. I can ask next time I see him, but he's real straight forward. For instance, he admitted he can't get the engine for 1300$ like he did a week ago, so he told me to wait until a better deal comes up. He could've said lets get the one for 2k, there's nothing else available. I kind of trust him and he did my rear end before that dealership couldn't fix.
Where would I look for an engine outside of ebay? Junkyards seem kind of sketchy
Unread 09-17-2014, 06:37 PM   #14
02blue
2002 KJ Liberty
http://www.powertrainproducts.net/
Unread 09-18-2014, 08:40 PM   #15
notsoeloquent
Originally Posted by 02blue View Post
Wow, these are still pricey. What do you guys think about this:
http://m.ebay.com/itm/290975570005?nav=SEARCH
