Why you should do some jobs yourself - JeepForum.com
post #1 of 15 Old 05-21-2013, 10:54 AM Thread Starter
lloyd59hen
My previous sparkplug changes were done at dealer. It was time to replace them, and since I am retired I have twice the time and half the money, I chose to change myself. But when I started removing the first plug, I knew I was in trouble, plug was very hard to break loose then as I was unscrewing, it was tight and squeaking as I turned. There was not a trace of antisieze on threads of any of the plugs. I was lucky in that all were removed wlthout damage. So the new ones went in fine with proper addition of antisieze, and hopefully will remove easier next time.
Lloyd Morris
lloyd59hen is offline
post #2 of 15 Old 05-21-2013, 11:00 AM
tjkj2002
2002 KJ Liberty
Antiseize should not be used on our plugs.They are required to be changed every 30k so no need and makes a mess of the threads which in turn can make removal very hard 2-3 plug changes down the road.
tjkj2002 is offline
post #3 of 15 Old 05-21-2013, 11:16 AM
Jeepguy4276
2002 KJ Liberty
Really, no anti-sieze? I've always used a thin amount when changing plugs on all the vehicles i've ever had. I haven't changed the ones in the liberty yet since i haven't had it long. I am going to in the next few weeks though. I would have automatically used anti-sieze. I didn't know it shouldn't be used on the liberty. Surprises me.
Jeepguy4276 is offline
post #4 of 15 Old 05-21-2013, 12:21 PM
tjkj2002
2002 KJ Liberty
Should never use antiseize on plugs or wheel studs.There is no mention of using antiseize in any FSM.I get to see the long term effects of antiseize on spark plugs and wheel studs everyday at work,just ends up costing the customer alot of $$$.Unless you 100% clean all the old antiseize off all threads(both male side and female side) don't ever use antiseize of spark plugs and wheel studs as it just gums up and cuases cross threading.
tjkj2002 is offline
post #5 of 15 Old 05-21-2013, 12:40 PM
Jeepguy4276
2002 KJ Liberty
Good to know. Thanks.
post #6 of 15 Old 05-21-2013, 01:23 PM
tjkj2002
2002 KJ Liberty
Just to be clear I am not against antiseize,just on those two areas is all.Use all you can on the suspension,more the tie rods and drag links.
tjkj2002 is offline
post #7 of 15 Old 05-21-2013, 02:22 PM
Jeepguy4276
2002 KJ Liberty
So your not anti- antisieze? Got it. Lol. No more antisieze on plugs and lugs.
post #8 of 15 Old 05-21-2013, 04:33 PM
TheBlueKJ
2003 KJ Liberty
Oh no.... I used antisieze on mine....
Blue 2003 Jeep Liberty Sport 4x4 Lifted, Front OME 790s/Bilstien, Custom Rear; 245/75/16 A/Ts KC Daylighters
thread)
TheBlueKJ is offline
post #9 of 15 Old 05-21-2013, 05:35 PM
ppap
If the plugs are torqued to spec and changed at the recommended intervals, you wont have any issues with their removal. I use a dab of anti-seize on exhaust related components, not spark plugs.
ppap is offline
post #10 of 15 Old 05-21-2013, 06:34 PM
TheBlueKJ
2003 KJ Liberty
So what can i do about it cleaning up the female threads?
thread)
post #11 of 15 Old 05-21-2013, 07:49 PM
jbarthol
2005 KJ Liberty
I'm worried if the OP'er used copper cores, if they didn't buy the Plugs ID'ed on the sticker. Said no mention of what plugs they used, and anything other than sticker model, or copper core isn't good either. I don't like anti sieze either, but that mostly because I don't want anyting getting in the cylinders other than gas.
jbarthol is offline
post #12 of 15 Old 05-21-2013, 08:00 PM
tjkj2002
2002 KJ Liberty
Copper core plugs are the correct OE plugs for the 3.7 in a KJ.NGK coppers came from the factory but Champion coppers are much better and the OE plugs for the 4.7 which is the big bother of the 3.7 V6.
Using anything but copper core plugs in the 3.7 can result in lower power,poor mpg's,and misfiring issues not to mention lightening your wallet much more then buying the correct plugs and changing them on time.
tjkj2002 is offline
post #13 of 15 Old 05-21-2013, 09:38 PM
jbarthol
2005 KJ Liberty
We sould really sticker thisfact. I know I asked this a few months ago when I first got my KJ. I'm having an odd case of Deja'vu right now.
jbarthol is offline
post #14 of 15 Old 05-21-2013, 09:45 PM
tommudd
2004 KJ Liberty
Spark plug discussions is much like your girlfriends monthly cycle.
You know its coming, but you don't want it to since you already know how its going to end
MUDD'S MOTORSPORTS
04 KJ JBA 4 INCH COILOVER LIFT
03 KJ JBA 2.5 TOTAL CONTROL LIFT
tommudd is offline
post #15 of 15 Old 05-22-2013, 06:37 AM
DaveJKJ
2005 KJ Liberty
I have used antiseize on plugs in the past a couple of times, but I don't anymore. Havn't used it on the KJ or the last couple of trucks I had.
I have been using the OEM NGK copper core plugs listed on the emissions sticker on the KJ and they have been changed several times (they are cheap and easy to change and it doesn't even take long to do). No problems.
(the e-3 plugs are crap......I tried them a long time ago on a trans-am and pulled them out and put in the factory gm spec ones).
Just my experience.
Lifted, Skids, Hooks, Rails, Trail Rash..
War Veterans Jeep Group #31
Black Jeep Society #217
DaveJKJ is offline
