Why won't my rear door open? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > Why won't my rear door open?
PANDEMIC-USA 50" Double row LED LIGHT BAR!! These thiANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete The Jeep Forum Discount is ON!
Unread 11-22-2010, 05:42 AM   #1
HialeahAngler
any of you had this experience? I unlock with the alarm or the key, and when I try to open it, you can hear it lock when I pull the handle. wth is going on?
2002 KJ Liberty
HialeahAngler is offline   Reply With Quote Quick reply to this message
Unread 11-22-2010, 11:17 AM   #2
LibertyTC
2004 KJ Liberty
You can search the forums under rear tailgate, door handle wont open etc. This is kinda a normal problem.
The handle it self can break a small plastic piece inside which requires the handle/mechanism replaced.
The electric door actuator can also get stuck and need replacement.
It is a matter of removing the tailgate inside plastic panel cover, and inspect it.
LibertyTC is offline   Reply With Quote Quick reply to this message
Unread 11-23-2010, 05:19 AM   #3
HialeahAngler
cool thanks. so I won't have any problem removing the plastic cover while the door is closed? it's gonna be tight. now I'm going to have to remove everything that's in the back. don't even ask! lol.
Unread 11-23-2010, 07:44 AM   #4
LibertyTC
2004 KJ Liberty
You may be able to get the tailgate open by removing the square inspection cover, did you do a search?
http://www.jeepforum.com/forum/f28/h...latch-953057/?
Hint push lock lever down.
Unread 11-24-2010, 05:57 AM   #5
HialeahAngler
thanks man. I haven't had time to check but that link sure did help. I should be able to take care of this tomorrow.
